So I found the Lokar throttle cable at o'reilly's. I replace the kickdown with the 3 piece and now I see some of the problems that i had. The original 1 piece for the 2 bbl DOES NOT WORK with the 4 bbl at all. It is too short no matter what. So you will see in the pic what my issue is. The throttle cable is catching on the kickdown and need to know if there is another way of doing this before I cut the cable to fit. Can I add some length and leave a longer loop of cable to avoid the kickdown? I was hoping I didnt have to buy the kickdown cable, seeing how they didnt have it in stock.
