help with 904 band adjust ! #954383
03/20/11 11:10 AM
03/20/11 11:10 AM
Georgia
moparjimbo60 Offline OP
Georgia
adjusted the bands on my 904 before going to the track yesterday. made 2 passes @6.74 and 6.75 next 2 passes were 6.80 and 6.79. the 6.80 was in the heat but the 79 was about 12 degrees cooler. but the shift from 1st to second seemed to overlap each other. second to third were fine . is the band to tight or too loose ?
Re: help with 904 band adjust ! [Re: moparjimbo60] #954384
03/20/11 11:19 AM
03/20/11 11:19 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
did it do it before the adjustment? if not then just back it off 1/8 to a 1/4 turn and see if it goes away, usually it is a 2-3 shift overlap/flare up problem, how is your tranny built? stock, rebuilt with good part's?
Re: help with 904 band adjust ! [Re: dartman366] #954385
03/20/11 11:22 AM
03/20/11 11:22 AM
Georgia
Georgia
yes it a rebuild with good clutches and steels, did not do it before. so its too tight ?
Re: help with 904 band adjust ! [Re: moparjimbo60] #954386
03/20/11 11:23 AM
03/20/11 11:23 AM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I adjust my front band 72" lbs & 2 1/2 turns out, my double wrap rear is 72"lbs & 4 turns out.What are your bands adjusted to?
Re: help with 904 band adjust ! [Re: DavidDean] #954387
03/20/11 11:25 AM
03/20/11 11:25 AM
Georgia
Georgia
i dont have an inch # wrench ,just always snug up then back off 2 and ahalf. but snug is a relative term.
Re: help with 904 band adjust ! [Re: moparjimbo60] #954388
03/20/11 11:45 AM
03/20/11 11:45 AM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
"snug" ? ... .... I have just done-it with a little-bitty open-end wrench USING the tip-O-my-finger
Re: help with 904 band adjust ! [Re: dOoC] #954389
03/20/11 12:07 PM
03/20/11 12:07 PM
Georgia
Georgia
yep thats what im talking about, but i could have got carried away
Re: help with 904 band adjust ! [Re: moparjimbo60] #954390
03/20/11 01:42 PM
03/20/11 01:42 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
My experience it does that when the band is too loose going into second
tighten 1/2 turn and try again. higher number kickdown levers 4.2 or 5.0
do not like to much play. 72 inch pounds 6 lbs is pretty tight so the wrist snug thing I go 1.5 turns back.
Re: help with 904 band adjust ! [Re: moparjimbo60] #954391
03/20/11 04:02 PM
03/20/11 04:02 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Does the valve body have LBA? What type of rear band, solid or double wrap?
If you have overlap on the 1-2 shift with a LBA valve body chances are the rear band is too tight, double wrap needs to be looser than 2 turns out.
Re: help with 904 band adjust ! [Re: John_Kunkel] #954392
03/20/11 06:22 PM
03/20/11 06:22 PM
Georgia
Georgia
turbo action trans brake valve body, has a solid band . so am i too loose or too tight you think ?
Re: help with 904 band adjust ! [Re: moparjimbo60] #954393
03/20/11 07:09 PM
03/20/11 07:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
too tight, like I said before back it off 1/4 turn and try it again and see if there is an improvement, I adjust mine as tight as my finger's will turn the stud in the center and back it off 1 and 1/2 turn's, I run a TA valvebody with a 4.2 lever.
Re: help with 904 band adjust ! [Re: dartman366] #954394
03/20/11 07:33 PM
03/20/11 07:33 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
+2, too tight, back it off like mentioned about 1/4 turn.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: help with 904 band adjust ! [Re: joedust451] #954395
03/20/11 10:05 PM
03/20/11 10:05 PM
Georgia
Georgia
thanks sooo much for the advice . im fixing it tommorow . you guys are the BOMB !
Re: help with 904 band adjust ! [Re: moparjimbo60] #954396
03/20/11 10:47 PM
03/20/11 10:47 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
let us know how it works.
