Re: help with 904 band adjust !
[Re: moparjimbo60]
#954384
03/20/11 11:19 AM
03/20/11 11:19 AM
dartman366
Mt. Vernon, Ohio
did it do it before the adjustment? if not then just back it off 1/8 to a 1/4 turn and see if it goes away, usually it is a 2-3 shift overlap/flare up problem, how is your tranny built? stock, rebuilt with good part's?
[Re: moparjimbo60]
#954388
03/20/11 11:45 AM
03/20/11 11:45 AM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
i dont have an inch # wrench ,just always snug up then back off 2 and ahalf. but snug is a relative term.
"snug" ? ... .... I have just done-it with a little-bitty open-end wrench USING the tip-O-my-finger
[Re: moparjimbo60]
#954390
03/20/11 01:42 PM
03/20/11 01:42 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
My experience it does that when the band is too loose going into second tighten 1/2 turn and try again. higher number kickdown levers 4.2 or 5.0 do not like to much play. 72 inch pounds 6 lbs is pretty tight so the wrist snug thing I go 1.5 turns back.
[Re: moparjimbo60]
#954391
03/20/11 04:02 PM
03/20/11 04:02 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Does the valve body have LBA? What type of rear band, solid or double wrap?
If you have overlap on the 1-2 shift with a LBA valve body chances are the rear band is too tight, double wrap needs to be looser than 2 turns out.
[Re: moparjimbo60]
#954393
03/20/11 07:09 PM
03/20/11 07:09 PM
dartman366
Mt. Vernon, Ohio
turbo action trans brake valve body, has a solid band . so am i too loose or too tight you think ?
too tight, like I said before back it off 1/4 turn and try it again and see if there is an improvement, I adjust mine as tight as my finger's will turn the stud in the center and back it off 1 and 1/2 turn's, I run a TA valvebody with a 4.2 lever.
[Re: moparjimbo60]
#954396
03/20/11 10:47 PM
03/20/11 10:47 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
thanks sooo much for the advice . im fixing it tommorow . you guys are the BOMB !
let us know how it works.
