Page 3 of 4 1 2 3 4
Re: How fast are you guys going with budget 440? [Re: viperblue72] #832437
10/19/10 12:09 AM
10/19/10 12:09 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
72 cudaracer
That seems pretty impressive!
Thanks.
It's not always how much you spend. Combination is the key. If all the parts are not pulling the rope in the same direction, it WILL disapoint and frustrate you.
Brian
Re: How fast are you guys going with budget 440? [Re: DragtimeDodge] #832438
10/19/10 08:13 AM
10/19/10 08:13 AM
an8sec70cuda Offline
446", 10:1, 93 octane pump gas, mufflers, 3,450 lbs with me. 10.61 @ 125 mph at a track with some altitude.
Wow, such a detailed description of your combo.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How fast are you guys going with budget 440? [Re: an8sec70cuda] #832439
10/19/10 08:55 AM
10/19/10 08:55 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
440, stock crank, heavy TRW pistons, stock rods, 11.0-1 with ported max wedge heads, MP 590 cam, vintage '63 cross ram with 750 eddy's, 727 w/2.77 first gear, 4500 stall, 4.10 Dana, 10.5x29" slicks, 3250(?) lbs, 11.20's. This engine needs more gear and the intake is the limiting factor (it would be faster with a good single 4bbl intake).
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: How fast are you guys going with budget 440? [Re: Dads426] #832440
10/19/10 09:00 AM
10/19/10 09:00 AM
nc
E
earthmover Offline
earthmover  Offline
E
nc
some good running big blocks here im keeping my on this
Re: How fast are you guys going with budget 440? [Re: earthmover] #832441
10/19/10 09:26 AM
10/19/10 09:26 AM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Anymore 3.23 or 3.55 combo's?
Re: How fast are you guys going with budget 440? [Re: '72CudaRacer] #832442
10/19/10 09:59 AM
10/19/10 09:59 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
72 cudaracer
Thanks.
Brian
I agree completely with this.When HardcoreB and I were in the planning stages I asked sooo many questions trying to make sure everything was going to play nice together. I could not afford to throw parts at it only to find out they didn't work. Pick a goal, figure out what it will take to achieve that goal, and do a lot of diligent hunting for deals on parts. They are out there. Do as much of the work yourself that you can and don't be afraid to ask questions. I'm very fortunate to have a good friend that I can bounce ideas off of and ask stupid questions to without being embarassed. Thank you Sean!
Randy
Re: How fast are you guys going with budget 440? [Re: SILVER67] #832443
10/19/10 10:01 AM
10/19/10 10:01 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
446 ci
Ported E heads
Scott Brown Solid cam
Indy dual plane
10:2 comp
750 dp carb
9.5 converter
3:55 gear
3600 pounds
11:48 @ 116 mph
Re: How fast are you guys going with budget 440? [Re: an8sec70cuda] #832444
10/19/10 07:54 PM
10/19/10 07:54 PM
DragtimeDodge Offline
The original question was "How fast you guys running with similar combos?" If my combination were very different I wouldn't have replied at all, and where it did differ I pointed it out. I didn't think that needed to be stated here.
Re: How fast are you guys going with budget 440? [Re: DragtimeDodge] #832445
10/19/10 07:57 PM
10/19/10 07:57 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
I would like to see some DOLLAR NUMBERS attached to some of these so-called budget-builds !
Re: How fast are you guys going with budget 440? [Re: dOc !] #832446
10/19/10 08:30 PM
10/19/10 08:30 PM
Bowler Wisconsin
Smoparmike Offline
Smoparmike  Offline
Bowler Wisconsin
30 over 440 ross pistons ly rods stock crank ported 452 heads comp cam 560 lift 265@50. M1 intake holley 1050hp(4150) Ptc converter 456 gears 30x9 slicks 64 Plymouth 3680# best 10.86@123. Bought motor off racing junk $2500.00. Five years ago. Mike
Re: How fast are you guys going with budget 440? [Re: dOc !] #832447
10/19/10 10:13 PM
10/19/10 10:13 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Budget is a relative term.
One mans budget may be another mans dream build.
My 440 combo,
.030 1976 short block .070 indahole $700.00
cast crank
LY rods
516 "doorstop" closed chamber heads $550.00
Street Dom. Intake $135.00
750 3310 vac. sec. $100.00
Milodon oil pan & pick-up $ 60.00
292/509 MP cam $100.00
timing gear & chain $ 45.00
oil pump $ 45.00
$1035.00 Total
All above parts were acquisitioned via swapmeet or internet.
It will go into a 3500 lb B-body with a
3400 Coan converter
fresh 727 w/rev. man. VB
4.10 or 4.30 gear (have both)
MP electronic ignition
and a pair of "old school" Holley Blue pumps with an external regulator and return line.
Hoping to break into the 12's.
Re: How fast are you guys going with budget 440? [Re: Dean_Kuzluzski] #832448
10/19/10 10:21 PM
10/19/10 10:21 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
My 440 combo,
cast crank
LY rods
oil pump $ 45.00
$1035.00 Total
3400 Coan converter
You should be able to hit low 12's easily with that combo.
Re: How fast are you guys going with budget 440? [Re: Dean_Kuzluzski] #832449
10/19/10 10:46 PM
10/19/10 10:46 PM
Florida STAYcation
Florida STAYcation
DeanO from Berri ....
550$ for a set of 516's ? ... thems must-be some double-trick door-stops !
And I agree .. that combo should be DEEEEP in-da-12's EZ !
Re: How fast are you guys going with budget 440? [Re: DragtimeDodge] #832450
10/20/10 08:23 AM
10/20/10 08:23 AM
Your original description is so vague that at a glance it seems impressive...but you left out the big parts of the combo that dictate whether or not it's a "budget" build like the OP asked for.
CHIP
Re: How fast are you guys going with budget 440? [Re: an8sec70cuda] #832451
10/20/10 09:32 AM
10/20/10 09:32 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
64 Dodge 2840# + 240# for the fat guy, best 10.08 @ 132
motor 440 +.055=451ci
Ross domes 14:1
Eagle rods
steel crank
620MP cam Crane rockers
E heads port matched
Victor intake 950hp
2" A body headers
8 3/4 rear 4.65 gear
ATI 8" 5000 stall
Best 10.08 at 132mph 60' 1.43, 1/8 6.38 at 107
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: How fast are you guys going with budget 440? [Re: wildcargo] #832452
10/20/10 03:14 PM
10/20/10 03:14 PM
Florida-West Coast
Thor500 Offline
Thor500  Offline
Florida-West Coast
66 Coronet 3650#w-driver
528 lift mech. cam
8.5:1
Source heads OTB
street dominator w 750dp
8"ta convertor
8 3/4 rear w. 4:30 gear
11.50 best with 1.59 60'
Re: How fast are you guys going with budget 440? [Re: dOc !] #832453
10/20/10 03:37 PM
10/20/10 03:37 PM
Holly/MI
Holly/MI
Uhhhh thanks.
That's how those swapmeet deals go sometimes.
It's a real world deal that I got a "deal" on some "budget" heads (castings, new valves 2.08/1.74, guides, valve job) and then take them to a known "good" machinist to set up the valve springs and he corrects the valvespring seat depth/width, valve guide height and then there's the price of the valve springs & retainers. Dude, it all adds up when you actually want to get something done with good machine work. Lesson learned............just use my own "barnfresh" castings, buy some required parts and go to one machinist.
At least my porting labor is free.
As the old saying goes..........."it's cost me hundreds to save a few $".
I do have other sets of heads that I've pulled together for less. But not by much.
Re: How fast are you guys going with budget 440? [Re: Blues_Cuda] #832454
10/30/10 10:37 PM
10/30/10 10:37 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
A real low budget 440...all factory parts except for pistons, valvetrain and accessories.
1975 cast crank 440 w/ stock rods, .030 Ross flat tops with an actual 10.3:1 cr using 1039 Fel-Pro gasket, Ultradyne .588 solid flat tappet cam, ported 906 heads, M-1 intake, AED 850 Holley, Hooker Comp headers, 9.5" PTC converter, 4.10 Dana 60 all in a '70 Barracuda street car. 3" TTI X-pipe exhaust all the way back to the factory style tips.
I have yet to reach the car's full potential due to suspension and carb tuning, but it has run 11.80-11.82 @ 116mph in full street trim on a 90+ degree day with crappy air. (All 4 passes that day were in that range.)
I know the car has 11.60's in it when everything is optimized and decent weather, but still need that timeslip to prove it. For giggles, I entered the 11.80 timeslip information on this DA calculator and it came back with an 11.57 ET. http://www.dragtimes.com/da-density-altitude-calculator.php Like I said above though...I want that timeslip to prove it.
The car is extremely streetable overall. We drive it all over town without issue.
An update in case anybody is interested...
I got the 11.57 out of the car today. The run before that was an 11.64 @ 118.26 mph.
Good air made the difference. Now I need to get to the suspension tuning.
Re: How fast are you guys going with budget 440? [Re: SILVER67] #832455
10/31/10 01:12 PM
10/31/10 01:12 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
1969 Roadrunner, 3700#, 3.23 gear, 91 oct gas
906 heads, big valves, iron rockers
10:1 TRW's, 6 pack rods, 509 cam
Holley Street Dominator intake, Holley 850
Solid 7 blade steel fan, stock alt. & pump
1.75 headers, 3500 stall 727 w shift kit
29.5 x 12.5 Sportsman Pro's
12.45 @ 110 in 4500 density altitude in 100+ degree heat in Las Vegas.
11.759 @ 111 DA corrected et.
I drove it to work and to the track often, that thing was a lot of fun when I put 4.30's, a dominator carb, and a small roller cam in it, ran a best of 11.48 @ 118.
Re: How fast are you guys going with budget 440? [Re: moparmanjames] #832456
10/31/10 05:15 PM
10/31/10 05:15 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Sounds like a nice running car.The cam, carb and gear change picked it up a bunch too. My junk: 68 Satellite glass 6 pak hood. 3.23, .030 over 8.5 , pocket ported 906s, stock valves.Comp 292 hyd, Torker, 750 DP, Hooker 1.85, GERRR 10 in., 28x9 M/Ts. 12.35 at 106 in cool fall Okla weather.
Page 3 of 4 1 2 3 4
