Re: 10 and 11 sec b bodys [Re: jef408] #754850
07/25/10 01:53 PM
07/25/10 01:53 PM
madison, ohio
modified1090 Offline
madison, ohio
10.80's 3250lbs, 12:1 440, .590mp cam, eddy heads,
4:88's in a dana 60, 14x32 hoosier tires,
running E85 through a 950 holley
Re: 10 and 11 sec b bodys [Re: jef408] #754851
07/25/10 02:30 PM
07/25/10 02:30 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
446 ported 346 iron heads,3900lbs.video in my signature.
GOTBOOST!?
Re: 10 and 11 sec b bodys [Re: jef408] #754852
07/25/10 02:46 PM
07/25/10 02:46 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Picture of my Charger. Hot Rod magazine year 1994 street/strip combo, when a Big block was a 440 and a good set of heads were 906
Re: 10 and 11 sec b bodys [Re: jef408] #754853
07/25/10 02:57 PM
07/25/10 02:57 PM
virginia
1x59rr Offline
1x59rr  Offline
virginia
69 rr. full interior, 8 point, 451 w/eddy rpm heads, 589 cam, 91/2 conv, m60 w/4:56 gears, 30x9's. runs 10:90's in the heat @ VMP.
Mark
69 RR
Re: 383man [Re: pro6pakRR] #754854
07/25/10 04:39 PM
07/25/10 04:39 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Holy crap the purple rr. Is gorgeous
Re: 383man [Re: sogtx] #754855
07/25/10 05:28 PM
07/25/10 05:28 PM
Whitinsville Ma
superbee500 Offline
superbee500  Offline
Whitinsville Ma
499 cu inch Indy SR heads mild 550 ish roller 11 to 1 comp 3200 ucc converter Demon carb cal tracks and 275 /60 MT drag radials 3900 lbs
Pump gas street car
Kevin
69 superbee 04 ram 3500
Re: 383man [Re: superbee500] #754856
07/26/10 12:15 AM
07/26/10 12:15 AM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
499, OOTB eddys, small solid, holley 950. 10" T/A converter and 3.55's and full exhaust. #3978 and 275/60 M&H drag radials. So far 11.87@113.7, I'm not that great at the track yet. You guys on here have some heavy cars that are quick!
Re: 10 and 11 sec b bodys [Re: WILD BILL] #754857
07/26/10 12:18 AM
07/26/10 12:18 AM
OHIO
THE GLASS MAN Offline
OHIO
Even a mild worn out low compression motor will push a B in to the low 11's high 10's if make it light enough
Re: 383man [Re: sogtx] #754858
07/26/10 01:01 AM
07/26/10 01:01 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
sogtx,if your talking about mine thank you.I've owned that car for 22 year's.It soon will have a 498in B1 head's and a 696 roller hope to go 10's.Also going to take off 30yr old air shock's and put on s/s spring's and real shock's
Chief
Wiseman Racing
Re: 383man [Re: pro6pakRR] #754859
07/27/10 06:17 AM
07/27/10 06:17 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Chief
Wiseman Racing
Yep yours , it just looks very mean .. All business , Good pic of your car ..
doesnt sound like your gonna have any problems doing 10's ..
Re: 10 and 11 sec b bodys [Re: jef408] #754860
07/27/10 03:42 PM
07/27/10 03:42 PM
Pittsburgh, PA
SmokeyBurnout 67 Offline
Pittsburgh, PA
Our 67 Coronet is still a street car. Its a 440 (30 over) with Indy SR heads custom hand ported by my father with Indy intake and 1000CFM Demon, TTI headers and of course some other Bowman goodies. Easy build and didnt really cost that much.
Uncapped and on slicks i run 10.90's 11.00's all day long. Capped and on street tires 11.40's. You have to have the combo. My compression is now 11.0 and we still run pump gas on the street.
Visit our website. I love quick B bodies!!!!!!
Good luck.
Kara Jo
Re: 10 and 11 sec b bodys [Re: WILD BILL] #754861
07/27/10 06:23 PM
07/27/10 06:23 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
...man that better be one light b-body..if only it were that easy..imo your about a 1.5 off it's more like 12.50's to high very high 11's..when i first got my car running, i was to impatient to wait and save $ to build my current short block...so i ended up running a early 70's rv413(maybe 8.5 to 1).it got new rings and a quick hone and put in new bearings. a MP484 cam and a stock set of 906's with a M1 and 780 carb. the car would run consistant 12.60's...my current comob is in my sig..i'm running Ross pistons(around 12-1)and BME alum. rods. and otb mp452 heads.runs consistant low 11.40's in the heat @ somewhere around 3600lbs.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: 10 and 11 sec b bodys [Re: racerAL] #754862
07/28/10 01:23 PM
07/28/10 01:23 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
My numbers are a little off from some of you guys. I'm going to chalk it up to a bad transmission and really old engine (been together for 17 years). New transmission goes in this summer and I'll be at PINKs at Firebird in November.
OOTB Edelbrock Performer Heads, .590 Purple Shaft, Crane 1.5 Golds, M1 Single Plane, 1150 3-circuit 4500, 2295 TRW, stock stroke steel crank, stock block, 100hp shot of N2O
69 Charger, almost full interior, caged, tubbed, ladder bars, unknown weight
727 (slipping into 3rd), 10inch 4000 converter
Run 1: Short shifting into 3rd, I botched the burn out.
R/T-----.390
60'-----1.565
330-----4.629
1/8-----7.239
MPH-----93.72
1000----9.495
1/4-----11.414
MPH-----117.94
Run 2: No short shifting, still botched the burn out.
R/T-----.238
60'-----1.582
330-----4.669
1/8-----7.287
MPH-----93.73
1000----9.542
1/4-----11.458
MPH-----118.23
Run 3: My only good burn out, waay over rev into 3rd.
R/T-----.164
60'-----1.636
330-----4.718
1/8-----7.355
MPH-----93.67
1000----9.610
1/4-----11.528
MPH-----118.01
Re: 10 and 11 sec b bodys [Re: gsmopar] #754863
07/29/10 02:40 AM
07/29/10 02:40 AM
Oh
His and Her 69's Offline
Oh
My beater that has run some 10.20's at 132 in the heat.
I still hope for a 9 sec pass yet this year.
3500 lbs with me in it. 493 cu, SR heads, 650 solid cam, 727, dana, 4.88, 1090 demon on gas.
I will do an E 85 swap, seal the carb to the hood yet this year.
David
