Re: 10 and 11 sec b bodys
[Re: jef408]
#754850
07/25/10 01:53 PM
07/25/10 01:53 PM
Posts: 257 madison, ohio
modified1090
madison, ohio
10.80's 3250lbs, 12:1 440, .590mp cam, eddy heads, 4:88's in a dana 60, 14x32 hoosier tires, running E85 through a 950 holley
[Re: jef408]
#754853
07/25/10 02:57 PM
07/25/10 02:57 PM
Posts: 27 virginia
1x59rr
virginia
69 rr. full interior, 8 point, 451 w/eddy rpm heads, 589 cam, 91/2 conv, m60 w/4:56 gears, 30x9's. runs 10:90's in the heat @ VMP.
Mark 69 RR
Re: 383man
[Re: sogtx]
#754855
07/25/10 05:28 PM
07/25/10 05:28 PM
Posts: 237 Whitinsville Ma
superbee500
Whitinsville Ma
499 cu inch Indy SR heads mild 550 ish roller 11 to 1 comp 3200 ucc converter Demon carb cal tracks and 275 /60 MT drag radials 3900 lbs Pump gas street car Kevin
69 superbee
04 ram 3500
Re: 383man
[Re: superbee500]
#754856
07/26/10 12:15 AM
07/26/10 12:15 AM
Posts: 878 Pittsburgh, Pa
Jeff_383
Pittsburgh, Pa
499, OOTB eddys, small solid, holley 950. 10" T/A converter and 3.55's and full exhaust. #3978 and 275/60 M&H drag radials. So far 11.87@113.7, I'm not that great at the track yet. You guys on here have some heavy cars that are quick!
[Re: WILD BILL]
#754857
07/26/10 12:18 AM
07/26/10 12:18 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Even a mild worn out low compression motor will push a B in to the low 11's high 10's if make it light enough
Re: 383man
[Re: pro6pakRR]
#754859
07/27/10 06:17 AM
07/27/10 06:17 AM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
sogtx,if your talking about mine thank you.I've owned that car for 22 year's.It soon will have a 498in B1 head's and a 696 roller hope to go 10's.Also going to take off 30yr old air shock's and put on s/s spring's and real shock's
Chief Wiseman Racing
Yep yours , it just looks very mean .. All business , Good pic of your car .. doesnt sound like your gonna have any problems doing 10's ..
[Re: jef408]
#754860
07/27/10 03:42 PM
07/27/10 03:42 PM
Posts: 156 Pittsburgh, PA
SmokeyBurnout 67
Pittsburgh, PA
Our 67 Coronet is still a street car. Its a 440 (30 over) with Indy SR heads custom hand ported by my father with Indy intake and 1000CFM Demon, TTI headers and of course some other Bowman goodies. Easy build and didnt really cost that much. Uncapped and on slicks i run 10.90's 11.00's all day long. Capped and on street tires 11.40's. You have to have the combo. My compression is now 11.0 and we still run pump gas on the street. Visit our website. I love quick B bodies!!!!!! Good luck. Kara Jo
[Re: racerAL]
#754862
07/28/10 01:23 PM
07/28/10 01:23 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
My numbers are a little off from some of you guys. I'm going to chalk it up to a bad transmission and really old engine (been together for 17 years). New transmission goes in this summer and I'll be at PINKs at Firebird in November. OOTB Edelbrock Performer Heads, .590 Purple Shaft, Crane 1.5 Golds, M1 Single Plane, 1150 3-circuit 4500, 2295 TRW, stock stroke steel crank, stock block, 100hp shot of N2O 69 Charger, almost full interior, caged, tubbed, ladder bars, unknown weight 727 (slipping into 3rd), 10inch 4000 converter Run 1: Short shifting into 3rd, I botched the burn out. R/T-----.390 60'-----1.565 330-----4.629 1/8-----7.239 MPH-----93.72 1000----9.495 1/4-----11.414 MPH-----117.94 Run 2: No short shifting, still botched the burn out. R/T-----.238 60'-----1.582 330-----4.669 1/8-----7.287 MPH-----93.73 1000----9.542 1/4-----11.458 MPH-----118.23 Run 3: My only good burn out, waay over rev into 3rd. R/T-----.164 60'-----1.636 330-----4.718 1/8-----7.355 MPH-----93.67 1000----9.610 1/4-----11.528 MPH-----118.01
