6 Pak Throttle Rods #3084917
10/10/22 05:40 PM
10/10/22 05:40 PM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Do any of you guys have any pictures of the throttle rods which show how they are hooked up to the center carb and end carbs? I think I have it, but want to make sure. Thanks, Kevin
Re: 6 Pak Throttle Rods [Re: B5TA] #3084948
10/10/22 07:14 PM
10/10/22 07:14 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 6 Pak Throttle Rods [Re: 70sixpkrt] #3085354
10/12/22 10:22 AM
10/12/22 10:22 AM
Ohio
B5TA Offline OP
B5TA  Offline OP
Ohio
Thanks for the Picture. I figured it out , the rods were correct, but I needed to flip the pivot assembly 180* So all is good THANK YOU !! Kevin
Re: 6 Pak Throttle Rods [Re: 70sixpkrt] #3085549
10/12/22 06:04 PM
10/12/22 06:04 PM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Originally Posted by 70sixpkrt
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them.
Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 6 Pak Throttle Rods [Re: VCODE] #3085561
10/12/22 07:20 PM
10/12/22 07:20 PM
70sixpkrt Offline
70sixpkrt  Offline
Thanks Bob
This picture is not my engine. I am running some stock bolts.
4-speed
3:54 Dana
Re: 6 Pak Throttle Rods [Re: VCODE] #3085672
10/13/22 06:16 AM
10/13/22 06:16 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Thanks Bob
They make two different lengths of H bolts. The 1.250 are for four barrels with the thick base gasket. Six pack used the 1.00” ones.
That intake and carbs is nicely detailed but the center pivot is not the correct oem one. That is an aftermarket piece. The oem used a pin with a clip instead of a bolt. Several companies sell the correct one. I think shakerhood.com does.
Re: 6 Pak Throttle Rods [Re: fastmark] #3085679
10/13/22 07:40 AM
10/13/22 07:40 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
Thanks Bob
Who sells the 1.00 inch ones.
Thanks Bob
Re: 6 Pak Throttle Rods [Re: VCODE] #3086061
10/14/22 05:29 PM
10/14/22 05:29 PM
Chicago
PurpleBeeper Offline
Chicago
just a tip.....the back mechanical return rod is VERY close to the intake and if installed backwards, it can just barely hang up against the intake when you are at wide-open-throttle & make the carburetors stick wide open (ask me how I know)
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 6 Pak Throttle Rods [Re: PurpleBeeper] #3087115
10/18/22 10:54 AM
10/18/22 10:54 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Exactly what happened to me in 1970 with my A12.
Showing off with a buddy in the car on an on-ramp, it hung up!!!
While I was busy stamping on the pedal and avoiding cars, my friend had the presence of mind to turn the key off.
My hair still stands up thinking about that one.
Joe
Re: 6 Pak Throttle Rods [Re: VCODE] #3087150
10/18/22 01:01 PM
10/18/22 01:01 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Thanks Bob
Thanks Bob
AMK fasteners
Re: 6 Pak Throttle Rods [Re: fastmark] #3087401
10/19/22 08:33 AM
10/19/22 08:33 AM
White Plains, NY
VCODE Offline
VCODE  Offline
White Plains, NY
AMK has them listed a 1-1/8 long.
Thanks Bob
Re: 6 Pak Throttle Rods [Re: VCODE] #3087425
10/19/22 10:12 AM
10/19/22 10:12 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Thanks Bob
I’ll check originals vs the two sizes I just bought from them. They probably are 1-1/8” long. The longer ones are for the thick Carter gaskets on the four barrel.
