Re: 6 Pak Throttle Rods
[Re: 70sixpkrt]
#3085549
10/12/22 06:04 PM
10/12/22 06:04 PM
Posts: 2,372 White Plains, NY
VCODE
White Plains, NY
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them. Thanks Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
[Re: VCODE]
#3085561
10/12/22 07:20 PM
10/12/22 07:20 PM
Posts: 3,680 South San Francisco, Ca
70sixpkrt
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them. Thanks Bob This picture is not my engine. I am running some stock bolts.
[Re: VCODE]
#3085672
10/13/22 06:16 AM
10/13/22 06:16 AM
Posts: 6,388 Abilene, Texas
fastmark
Abilene, Texas
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them. Thanks Bob They make two different lengths of H bolts. The 1.250 are for four barrels with the thick base gasket. Six pack used the 1.00” ones. That intake and carbs is nicely detailed but the center pivot is not the correct oem one. That is an aftermarket piece. The oem used a pin with a clip instead of a bolt. Several companies sell the correct one. I think shakerhood.com does.
[Re: fastmark]
#3085679
10/13/22 07:40 AM
10/13/22 07:40 AM
VCODE
White Plains, NY
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them. Thanks Bob They make two different lengths of H bolts. The 1.250 are for four barrels with the thick base gasket. Six pack used the 1.00” ones. That intake and carbs is nicely detailed but the center pivot is not the correct oem one. That is an aftermarket piece. The oem used a pin with a clip instead of a bolt. Several companies sell the correct one. I think shakerhood.com does. Who sells the 1.00 inch ones. Thanks Bob
[Re: VCODE]
#3086061
10/14/22 05:29 PM
10/14/22 05:29 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
just a tip.....the back mechanical return rod is VERY close to the intake and if installed backwards, it can just barely hang up against the intake when you are at wide-open-throttle & make the carburetors stick wide open (ask me how I know)
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: PurpleBeeper]
#3087115
10/18/22 10:54 AM
10/18/22 10:54 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Exactly what happened to me in 1970 with my A12. Showing off with a buddy in the car on an on-ramp, it hung up!!!
While I was busy stamping on the pedal and avoiding cars, my friend had the presence of mind to turn the key off. My hair still stands up thinking about that one.
Joe
[Re: VCODE]
#3087150
10/18/22 01:01 PM
10/18/22 01:01 PM
fastmark
Abilene, Texas
Are you using the carb H bolt 1-1/4 inch long. I took off carbs off a 340 -6 and someone cut them. Does not seem like the intake manifold treads a deep enough for the bolts without cutting them. Thanks Bob They make two different lengths of H bolts. The 1.250 are for four barrels with the thick base gasket. Six pack used the 1.00” ones. That intake and carbs is nicely detailed but the center pivot is not the correct oem one. That is an aftermarket piece. The oem used a pin with a clip instead of a bolt. Several companies sell the correct one. I think shakerhood.com does. Who sells the 1.00 inch ones. Thanks Bob AMK fasteners
[Re: fastmark]
#3087401
10/19/22 08:33 AM
10/19/22 08:33 AM
VCODE
White Plains, NY
AMK has them listed a 1-1/8 long. Thanks Bob
[Re: VCODE]
#3087425
10/19/22 10:12 AM
10/19/22 10:12 AM
fastmark
Abilene, Texas
AMK has them listed a 1-1/8 long. Thanks Bob I’ll check originals vs the two sizes I just bought from them. They probably are 1-1/8” long. The longer ones are for the thick Carter gaskets on the four barrel.
