Re: Street Outlaws. Now I've seen it ALL (Reaper)
[Re: TRENDZ]
#2218581
12/21/16 08:59 PM
12/21/16 08:59 PM
Posts: 580 Livermore, CA
Dduster
Livermore, CA
Reaper can't catch a break. Really would like to see some clean trouble free passes from him. I wonder why Reaper doesn't take His car down to Thunder Valley south of Noble and get that car straightened out there? Legit NHRA tight track, no goofball goat rodeo crowd/audience,... focus on getting clean dry hard launches and then go back to that TV business after things are cleared up. Seems like much more trouble to do the 'figure it out' in front of Your competition/everyone action?
[Re: pittsburghracer]
#2218595
12/21/16 09:26 PM
12/21/16 09:26 PM
Posts: 10,021 MN
JERICOGTX
MN
Reapers new engine looked good at PRI.
69 GTX
68 Road Runner
[Re: Dduster]
#2218627
12/21/16 10:24 PM
12/21/16 10:24 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Reaper can't catch a break. Really would like to see some clean trouble free passes from him. I wonder why Reaper doesn't take His car down to Thunder Valley south of Noble and get that car straightened out there? Legit NHRA tight track, no goofball goat rodeo crowd/audience,... focus on getting clean dry hard launches and then go back to that TV business after things are cleared up. Seems like much more trouble to do the 'figure it out' in front of Your competition/everyone action? The plug incident was at Thunder Valley. Exploded trans...Thunder valley. He and all the others go there a lot. Lutz, Chief and Murder Nova testing last week..........Thunder Valley. They usually do it down past the finish line. The car is a rocket when it makes a clean hit, as seen by him putting about 5 on Dave and losing to Chief by a nose, when he really wasn't setup to run Chief that night. These guys are ALL so fast now, that when it's your night, it's your night. If not you look dumb. I know I don't usually talk about stuff that hasn't aired, but giving an example here. It's pretty obvious Doc's car is a beast and as fast as anything there. He made a tire change and a couple other things and dropped to 8th on the list before he could stop the bleeding recently
[Re: Monte_Smith]
#2218658
12/21/16 11:25 PM
12/21/16 11:25 PM
Posts: 4,457 Washington
madscientist
Washington
Reaper can't catch a break. Really would like to see some clean trouble free passes from him. I wonder why Reaper doesn't take His car down to Thunder Valley south of Noble and get that car straightened out there? Legit NHRA tight track, no goofball goat rodeo crowd/audience,... focus on getting clean dry hard launches and then go back to that TV business after things are cleared up. Seems like much more trouble to do the 'figure it out' in front of Your competition/everyone action? The plug incident was at Thunder Valley. Exploded trans...Thunder valley. He and all the others go there a lot. Lutz, Chief and Murder Nova testing last week..........Thunder Valley. They usually do it down past the finish line. The car is a rocket when it makes a clean hit, as seen by him putting about 5 on Dave and losing to Chief by a nose, when he really wasn't setup to run Chief that night. These guys are ALL so fast now, that when it's your night, it's your night. If not you look dumb. I know I don't usually talk about stuff that hasn't aired, but giving an example here. It's pretty obvious Doc's car is a beast and as fast as anything there. He made a tire change and a couple other things and dropped to 8th on the list before he could stop the bleeding recently That's just how quickly it can go sideways. Something that looks as simple as a tire change can change anything and everything including IC and shock settings, launch RPM etc. I've already posted I had a 1/2 inch wrench go through an engine. It happens.
#2218684
12/21/16 11:59 PM
12/21/16 11:59 PM
Monte_Smith
North Alabama
When Doc had the car redone by a very well known chassis builder, I cautioned him to NOT let the guy move the motor back. A Monte Carlo already has a long wheelbase and good motor position. It needed to be built like a pro nitrous car, meaning about 54% nose weight. He(builder) did as he wanted because he had "street car" in his head and the car is 50/50. It's been a constant struggle to keep it from hammering the tire and shaking. On another racers advice, albeit one with a totally different combo, Doc tried a different tire that was actually a MORE aggressive tire. That didn't go well........LOL!!!! We really need to move the motor forward, but that's MAJOR surgery. Plus it really won't hold the tire we NEED because Doc didn't want to bubble the 1/4 panels. So would have to raise the car to fit them, which isn't good either
[Re: Monte_Smith]
#2218700
12/22/16 12:20 AM
12/22/16 12:20 AM
madscientist
Washington
When Doc had the car redone by a very well known chassis builder, I cautioned him to NOT let the guy move the motor back. A Monte Carlo already has a long wheelbase and good motor position. It needed to be built like a pro nitrous car, meaning about 54% nose weight. He(builder) did as he wanted because he had "street car" in his head and the car is 50/50. It's been a constant struggle to keep it from hammering the tire and shaking. On another racers advice, albeit one with a totally different combo, Doc tried a different tire that was actually a MORE aggressive tire. That didn't go well........LOL!!!! We really need to move the motor forward, but that's MAJOR surgery. Plus it really won't hold the tire we NEED because Doc didn't want to bubble the 1/4 panels. So would have to raise the car to fit them, which isn't good either I would expect a car built to that level would be able to move some weight forward. Then again, moving weight forward changes everything and requires everything else to be redone. Then again, if you think the engine is too far back, it's hard to move that much weight forward without moving the engine. He is in a tough spot.
#2218701
12/22/16 12:25 AM
12/22/16 12:25 AM
Monte_Smith
North Alabama
There is nothing to move. Nothing in the rear of car but tubing and body. The motor is just too far back. Next thing is to hang some weight in the front and give it a go.
This is what we got into with Pro Nitrous cars when split window Vettes were the popular body. They just inherently had too much bite because of engine position once they all went to the BIG motors. Just couldn't get enough nose weight. And if you notice now, you never see NEW Pro Nitrous split windows
[Re: cudaman1969]
#2218707
12/22/16 12:34 AM
12/22/16 12:34 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Heck, it's a Chevy engine, who cares. Hope they all do it, end of show. care to point out any piece on Reaper's engine that will bolt onto a production chevy engine?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
#2218726
12/22/16 12:53 AM
12/22/16 12:53 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I also put my plugs in my carb, always say I am going to get a tray for the carb and never do. It's easy to keep them in order in the carb, even do it on Brett's motor and Tory's too. I guess I am dumb.
Hated to see reaper hurt his motor, but it wasn't his fault. I know of another guy that had a helper spray carb cleaner on a spounge on the bottom of a lift off hood, to clean some grease off. Then set hood on roof of painted car. What can you do he was there helping you out. Sucks when it happens.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Spaceman Spiff]
#2218833
12/22/16 07:28 AM
12/22/16 07:28 AM
Posts: 8,241 fredericksburg,va
cudaman1969
fredericksburg,va
Heck, it's a Chevy engine, who cares. Hope they all do it, end of show. care to point out any piece on Reaper's engine that will bolt onto a production chevy engine? Back with THAT bs again. Where you put a bolt has nothing to do with what engine design it is. I guess Toyota builds top fuel engines now since there name is on the butterflies. With what you're saying we can't call a it 9 inch Ford rear anymore since nothing is used from Ford, Strange, MW makes the stuff now. Can't call it a power glide, Chevy don't make it. All aftermarket. New parts are made everyday but it still comes down to a core design. No amount of debating will change that.
[Re: dvw]
#2219094
12/22/16 04:44 PM
12/22/16 04:44 PM
madscientist
Washington
As always the show is full of Drama. It keeps most of us watching. I take it with a grain of salt. Anybody has made mistakes that have cost us, not just in cars, but life in general. I got to give him credit for how calm he was when they discovered the issue. Maybe it was staged? That is a sign of someone with a real mind set to accomplish a goal. I wish I had half the knowledge these guys do about car set-up, no dummies. Doug I doubt that was staged. Maybe James realizes he isn't perfect. The guy was new. Try finding someone under 35 to work on this stuff. It's almost impossible to find them. What good would getting pissed off had done?
[Re: Monte_Smith]
#2219113
12/22/16 05:12 PM
12/22/16 05:12 PM
Posts: 2,855 Pattison Texas
CSK
Pattison Texas
Oh it definitely wasn't staged, that motor was nearly brand new and it cost him over 10 grand to fix it. On camera James can come across as a hot head, but he is really not. Most would have come unglued when that happened, he didn't. As far as "new guy" Mike......he was with James when they brought car here and we were ribbing him about the plug deal. Mike still felt bad, but James was over it Thanks again Monte for posting on this forum.
[Re: madscientist]
#2219117
12/22/16 05:17 PM
12/22/16 05:17 PM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
What good would getting pissed off had done? Absolutely nothing, the damage was already done. I was chuckling when I grenaded my last nearly new engine. Not much you can do but laugh at this stuff sometimes. It was totally my fault too due to miscalculating the compression ratio, multiple times.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
