Locked distributor advance #172032
12/20/08 10:58 PM
12/20/08 10:58 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
How many of you guys have your advance locked on your distributors? Would like to know reasoning and basic engine combos. Thanks, Beep
Re: Locked distributor advance [Re: Bigbeep] #172033
12/20/08 11:11 PM
12/20/08 11:11 PM
Dizzy's are locked out when using crank trigger... it can be a problem starting motor due to timing is at full advance from the go..some mills you can get cranking and flip on the ignition and it works fine..I had this setup on my motor and fought kick-backs, broken starters and starter ring gears...It is not worth the extra cash for the trigger in my opinion...
Re: Locked distributor advance #172034
12/20/08 11:32 PM
12/20/08 11:32 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mines locked out
No problems starting either
Re: Locked distributor advance [Re: WILD BILL] #172035
12/20/08 11:50 PM
12/20/08 11:50 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Mine has been locked out for the last two years!
No kickback yet!
Ed
Post deleted by Defbob [Re: WILD BILL] #172036
12/20/08 11:50 PM
12/20/08 11:50 PM
Re: Locked distributor advance #172037
12/20/08 11:56 PM
12/20/08 11:56 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
locked timing *35-*38 and msd start retard box
1.39 9.85 - 137 mph
Re: Locked distributor advance [Re: Ari440] #172038
12/21/08 04:34 AM
12/21/08 04:34 AM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Thanks guys.
Ari440, Does your start retard pull 20* when cranking? I think the one I have is capable of that. Beep
Re: Locked distributor advance [Re: Bigbeep] #172039
12/21/08 06:06 AM
12/21/08 06:06 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've locked my dizzy but then i'm using a timing computer & crank trigger. timing is 18* on start up, 23* from 500 - 4000rpm(brake limiter set at 38)4000 - 7500rpm 36* & decreases every 100 rpm above that. easy starting with this program & full power dont come on till after the brake is released & going for converter stall of 5500 rpm, easy on the engine this way
Re: Locked distributor advance [Re: rebel] #172040
12/21/08 06:37 AM
12/21/08 06:37 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
I run a FBO distributor. It has 10* advance built in. Full advance by 1800 rpm. My timing is set at 25* initial, and 35* full advance. Works for me. I spin the motor 1st, and then flip the ignition switch. Vrooom!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: Locked distributor advance [Re: Bigbeep] #172041
12/21/08 09:52 AM
12/21/08 09:52 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
Mine is locked out at 33°.
I use a MSD 7 3 AL with the 25° start retard
Re: Locked distributor advance [Re: Bigbeep] #172042
12/21/08 11:16 AM
12/21/08 11:16 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Thanks guys.
yes
1.39 9.85 - 137 mph
Re: Locked distributor advance [Re: Bigbeep] #172043
12/21/08 01:03 PM
12/21/08 01:03 PM
Rowlett, TX
74DusterP457 Offline
mopar addict
mopar addict
Rowlett, TX
I've offered this once before.
Buy a set of light advance springs.
Remove the two installed springs, install one of the light springs.
Advance is very quick and no starting problems. For the street, you can't beat this little trick
Paul
Re: Locked distributor advance [Re: 74DusterP457] #172044
12/21/08 01:43 PM
12/21/08 01:43 PM
paul(quote)
That's what I did as well, works great..No need for a $200 digital retard box and a trigger.
Re: Locked distributor advance [Re: Bigbeep] #172045
12/21/08 07:03 PM
12/21/08 07:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Locked out street/strip car 12.11 comp. stroked 400(470)and starts and runs fine even on 91 pump swill. Been that way for years and to me it`s easier than messing w/springs and bushings + idles better and can set total advance at idle w/out winging the hell out of the motor.
Re: Locked distributor advance [Re: Thumperdart] #172046
12/21/08 07:12 PM
12/21/08 07:12 PM
Central Ohio, USA
Bigbeep Offline OP
Bigbeep  Offline OP
Central Ohio, USA
Lots of good info here guys. Thanks. Just running ideas and options thru my thick skull now. Beep
Re: Locked distributor advance [Re: 74DusterP457] #172047
12/21/08 08:48 PM
12/21/08 08:48 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Paul
one light spring
Re: Locked distributor advance [Re: sixpackgut] #172048
12/21/08 08:54 PM
12/21/08 08:54 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I use an MSD Distributor with the light springs and black(largest) stop. Timing is 17 at idle and 35 by 2400 rpm, no starting problems and has a lot cleaner idle.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Locked distributor advance [Re: 67HEMI] #172049
12/22/08 01:48 AM
12/22/08 01:48 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
One light spring, interesting
How soon do you get full advance with that setup (MSD dizzy)?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Locked distributor advance [Re: Sledge_57] #172050
12/22/08 09:44 AM
12/22/08 09:44 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
as soon as it starts
Re: Locked distributor advance [Re: sixpackgut] #172051
12/22/08 01:20 PM
12/22/08 01:20 PM
Q
Quicktree Offline
Quicktree  Offline
Q
problem only running one spring is you some time get rpm's going up and down. if you run one light silver and one light blue it will keep it stable and accomplish the same thing
