Re: Locked distributor advance
[Re: Bigbeep]
#172033
12/20/08 11:11 PM
12/20/08 11:11 PM
How many of you guys have your advance locked on your distributors? Would like to know reasoning and basic engine combos. Thanks, Beep
Dizzy's are locked out when using crank trigger... it can be a problem starting motor due to timing is at full advance from the go..some mills you can get cranking and flip on the ignition and it works fine..I had this setup on my motor and fought kick-backs, broken starters and starter ring gears...It is not worth the extra cash for the trigger in my opinion...
#172034
12/20/08 11:32 PM
12/20/08 11:32 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Mines locked out
No problems starting either
Post deleted by Defbob
[Re: WILD BILL]
#172036
12/20/08 11:50 PM
12/20/08 11:50 PM
#172037
12/20/08 11:56 PM
12/20/08 11:56 PM
Posts: 5,618 long island NY
Ari440
long island NY
locked timing *35-*38 and msd start retard box
1.39 9.85 - 137 mph
[Re: Ari440]
#172038
12/21/08 04:34 AM
12/21/08 04:34 AM
Posts: 1,165 Central Ohio, USA
Bigbeep
Central Ohio, USA
Thanks guys. Ari440, Does your start retard pull 20* when cranking? I think the one I have is capable of that. Beep
[Re: rebel]
#172040
12/21/08 06:37 AM
12/21/08 06:37 AM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I run a FBO distributor. It has 10* advance built in. Full advance by 1800 rpm. My timing is set at 25* initial, and 35* full advance. Works for me. I spin the motor 1st, and then flip the ignition switch. Vrooom!!
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: 74DusterP457]
#172044
12/21/08 01:43 PM
12/21/08 01:43 PM
I've offered this once before.
Buy a set of light advance springs.
Remove the two installed springs, install one of the light springs.
Advance is very quick and no starting problems. For the street, you can't beat this little trick paul(quote)
That's what I did as well, works great..No need for a $200 digital retard box and a trigger.
[Re: Bigbeep]
#172045
12/21/08 07:03 PM
12/21/08 07:03 PM
Thumperdart
State of confusion
Locked out street/strip car 12.11 comp. stroked 400(470)and starts and runs fine even on 91 pump swill. Been that way for years and to me it`s easier than messing w/springs and bushings + idles better and can set total advance at idle w/out winging the hell out of the motor.
[Re: sixpackgut]
#172048
12/21/08 08:54 PM
12/21/08 08:54 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I use an MSD Distributor with the light springs and black(largest) stop. Timing is 17 at idle and 35 by 2400 rpm, no starting problems and has a lot cleaner idle.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: 67HEMI]
#172049
12/22/08 01:48 AM
12/22/08 01:48 AM
Posts: 4,027 Dearborn Hts, MI
Sledge_57
Dearborn Hts, MI
One light spring, interesting How soon do you get full advance with that setup (MSD dizzy)?
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
[Re: sixpackgut]
#172051
12/22/08 01:20 PM
12/22/08 01:20 PM
Quicktree
as soon as it starts
problem only running one spring is you some time get rpm's going up and down. if you run one light silver and one light blue it will keep it stable and accomplish the same thing
