Re: Locked distributor advance
[Re: Bigbeep]
#172033
12/20/08 11:11 PM
12/20/08 11:11 PM
How many of you guys have your advance locked on your distributors? Would like to know reasoning and basic engine combos. Thanks, Beep
Dizzy's are locked out when using crank trigger... it can be a problem starting motor due to timing is at full advance from the go..some mills you can get cranking and flip on the ignition and it works fine..I had this setup on my motor and fought kick-backs, broken starters and starter ring gears...It is not worth the extra cash for the trigger in my opinion...
