Re: max wedge nascar intake
[Re: keith airgrabber]
#1688037
10/19/14 09:21 PM
10/19/14 09:21 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
I kinda think you would be ok using some J B Weld stick, filling up that hole.
I too have one of those intakes, and when i got it, i put it in the bead cleaner to make it look spiffy.
The aluminum was porus on one runner, and started putting a hole in the top of the runner with the blast of the bead agent.
Used JB Weld on it, and it worked great, to this day.
RF-4C Phantom 69-370 Zweibrucken, Germany
#1688039
10/19/14 10:47 PM
10/19/14 10:47 PM
Posts: 528 SW CO
HemiSportFury
SW CO
I wouldn't think that small of a hole would have much if any effect on the fuel distribution. The DP4B's used to have a hole in the divider plate. I know because I ran a Holley three barrel on one back in the day. The rectangular hole or slot was necessary to clear the secondary throttle plate. It was not something I added, they were made that way.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60 '57 Belvedere 2dr sedan, current project in process '19 Cherokee Trail Hawk Elite '03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
[Re: thehemikid]
#1688042
10/20/14 09:42 AM
10/20/14 09:42 AM
Posts: 422 wisconsin united states
keith airgrabber
Right in the Nutz!!!
hemi71x, was this a pic you posted a good while back?
The one I found 20yrs ago was cut also. That one from 20 years ago looks like it was already like that from the factory. I have a little Hot Rod Plymouth book that shows a factory drawing or blueprint and that looks correct. Maybe some were cut and some were't.
#1688043
10/20/14 12:08 PM
10/20/14 12:08 PM
hemi71x
Yes, no doubt the plenum was cut, modified, for someones application. But they all started life as a 4 hole manifold, then after that, anybody could have done anything they wanted to, with the intake.
