max wedge nascar intake #1688032
10/19/14 08:50 PM
10/19/14 08:50 PM
wisconsin united states
K
keith airgrabber Offline OP
Right in the Nutz!!!
K
part#2465165 I saw this on craigslist this morning and bought it. It has been butchered up top a little. But I am going to fix it. I almost passed on it but I never saw one of these and I thought I should still buy it. according to some old magazine articles it is an improved verion of the single plenum max wedge nascar intake. It has dual ports to still give some ram tuning and more power throughout rpm range. I am going to see if someone can tig weld it and then I will just grind it down smooth as I can. It had epoxy covering the hole in the picture. I just finished cleaning it all out. It sucked. I paid $250. But even damaged it was just too cool to pass on. Someone ground out the carb area so bad they went through a plenum wall. Who are these people that do this. What are they thinking. I want opinions on if the carb will seal with a standard gasket? The guy I bought it from had a carb spacer mounted permanent. But I removed for now to see what damage there really was. I hope there is enough flange left for a carb too seal. I have a max wedge clone I am building. And thought if I ever want just a four barrel on it . This one I would like too use.
Re: max wedge nascar intake [Re: keith airgrabber] #1688033
10/19/14 08:54 PM
10/19/14 08:54 PM
K
K
Re: max wedge nascar intake [Re: keith airgrabber] #1688034
10/19/14 08:55 PM
10/19/14 08:55 PM
K
K
carb spacer on it to serve as a sealing method.
Re: max wedge nascar intake [Re: keith airgrabber] #1688035
10/19/14 09:00 PM
10/19/14 09:00 PM
K
K
hole in plenum that needs filling. Or would it not really effect the air fuel mixture too much if I just left it??
Re: max wedge nascar intake [Re: keith airgrabber] #1688036
10/19/14 09:01 PM
10/19/14 09:01 PM
K
K
hacked carb opening
Re: max wedge nascar intake [Re: keith airgrabber] #1688037
10/19/14 09:21 PM
10/19/14 09:21 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
I kinda think you would be ok using some J B Weld stick, filling up that hole.
I too have one of those intakes, and when i got it, i put it in the bead cleaner to make it look spiffy.
The aluminum was porus on one runner, and started putting a hole in the top of the runner with the blast of the bead agent.
Used JB Weld on it, and it worked great, to this day.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: max wedge nascar intake [Re: hemi71x] #1688038
10/19/14 09:59 PM
10/19/14 09:59 PM
K
K
Yeah, I thought about jb weld. It worked good on the bottom of my boat. I just woor about it coming off going into the motor.The Jb weld stick is kind of like a putty till it hardens if I am not mistaken. Maybe if it gets sandwiched on both sides of the hole it could work and not fall off.
Re: max wedge nascar intake [Re: keith airgrabber] #1688039
10/19/14 10:47 PM
10/19/14 10:47 PM
SW CO
HemiSportFury Offline
SW CO
I wouldn't think that small of a hole would have much if any effect on the fuel distribution. The DP4B's used to have a hole in the divider plate. I know because I ran a Holley three barrel on one back in the day. The rectangular hole or slot was necessary to clear the secondary throttle plate. It was not something I added, they were made that way.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
Re: max wedge nascar intake [Re: HemiSportFury] #1688040
10/20/14 03:22 AM
10/20/14 03:22 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
hemi71x, was this a pic you posted a good while back?
The one I found 20yrs ago was cut also.
Re: max wedge nascar intake [Re: thehemikid] #1688041
10/20/14 08:00 AM
10/20/14 08:00 AM
hemi71x Offline
hemi71x  Offline
[image]
http://i898.photobucket.com/albums/ac190...9df.jpg[/image]
Yep.
Those are my intakes.
Left to right:
1959-61 Aluminum NASCAR 4bbl intake for the 413 engine.
1964 Nascar Max Wedge 426 4bbl intake
1962-63 Nascar Max Wedge 413 4bbl intake.
Re: max wedge nascar intake [Re: thehemikid] #1688042
10/20/14 09:42 AM
10/20/14 09:42 AM
K
K
The one I found 20yrs ago was cut also. That one from 20 years ago looks like it was already like that from the factory. I have a little Hot Rod Plymouth book that shows a factory drawing or blueprint and that looks correct. Maybe some were cut and some were't.
Re: max wedge nascar intake [Re: keith airgrabber] #1688043
10/20/14 12:08 PM
10/20/14 12:08 PM
hemi71x Offline
hemi71x  Offline
Yes, no doubt the plenum was cut, modified, for someones application.
But they all started life as a 4 hole manifold, then after that, anybody could have done anything they wanted to, with the intake.
