Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES!
[Re: JohnRR]
#1477929
08/11/13 02:17 PM
08/11/13 02:17 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
It was ALOT more me than him. I'm the one trying to squeeze as much for as little. Just for the record, the HS's have been ordered and in route OUCH! Thumper dart, nice shot! Reminds me while as a younger man watching Mr. Mike Toot and his bad ass Dart's @ Miami Hollywood International Speedway.
Which Harland sharps did you get? The ones you need are only available thru Mancini , at least they were only available thru Mancini , they are bushed on the shaft instead of full roller bearing.
From what I read, I would prefer the bushed rockers. A relatively low lift cam doesn't benefit from needle bearing. That being said (my ). I will not question my builders choice on the rockers. Looking forward to the Dyno run-in soon!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1477930
08/11/13 02:44 PM
08/11/13 02:44 PM
Copper Dart
I don't see any bushed Harland Sharp roller rockers on Mancini's web site for RB Mopars. Am I missing something or are they special order or something?
[Re: Twostick]
#1477933
08/11/13 04:10 PM
08/11/13 04:10 PM
Copper Dart
I was told the roller to valve tip issue has be resolved using the HS's. He didn't say anything about the Pushrod clearance so I take it that was resolved too. I hope to hear it run soon!
[Re: d7cook]
#1477936
08/12/13 12:41 AM
08/12/13 12:41 AM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
http://www.manciniracing.com/free_flyer/pdf/Mancini%20Spring%2013.pdf
Page 7
Product Description Axle Differential Case, Chrysler 8.75 in., Nodular Iron, 1.875 in. Bearing Bore, 30 Spline, Each
Yukon Gear & Axle iron third member cases are made from heavy-duty nodular iron for maximum strength. These cases are offered in performance and OEM replacement styles for a range of applications. Yukon third member cases are designed to perform and built to last!
Note: Includes billet side adjusters.
Mancinis roller rockers don't state there are bushed or needle bearing, the Hughes do state they are bushed however.
[Re: Quicktree]
#1477937
08/12/13 01:07 AM
08/12/13 01:07 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
WELL YOU USED TWO OF THE CHEAPEST PIECES ON THE MARKET WHAT DID YOU EXPECT?
REAL HELPFUL THERE D-BAG !!
NOT EVERYONE HAS $$$$ FOR T&D ROCKERS AND INDY HEADS !!
MY "CHEAP CHINESE" 440SOURCE PARTS ARE STILL ROCKIN ...SINCE 2007 ! BET THAT MAKES YOU A LITTLE BUTTHURT. I KNOW IT DOES.
WELCOME TO MY IGNORE LIST D-BAG.
[Re: Skeptic]
#1477938
08/12/13 01:51 AM
08/12/13 01:51 AM
Posts: 290 Cincinnati, Ohio
d7cook
Cincinnati, Ohio
Page 7 on the flyer say they are bushed. I just put a set on Performer heads and they seem like good pieces for the price.
1967 Coronet, 1989 Daytona tube chassis.
Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT.
-Banned for life from V8Buick.com-
[Re: 493_DART]
#1477940
08/12/13 06:34 AM
08/12/13 06:34 AM
Quicktree
good i hope someone tells you to stick it for me
[Re: Hot 340]
#1477941
08/12/13 11:01 AM
08/12/13 11:01 AM
Copper Dart
I believe they can be returned. My pockets are near empty so witch ones to choose? Even with the refund, I believe I'll be spending another $300. +|-
You simply cannot imagine what even just one elcheapo part can do to set off an entire chain reaction of problems. That last time I helped someone with his engine he bought a few of these "bargain" parts and he ended up selling the car out of disgust. Buy good rockers.
elcheapo considering that the parts are made in China, wouldn't the correct term be maybe ChaChingCheapo For what its worth, my wife, that puts up with me and my obsession with my cars, is Chinese! I Love You Baby!
UPDATE
[Re: Copper Dart]
#1477942
08/14/13 09:01 AM
08/14/13 09:01 AM
Copper Dart
tic tock tic tock...............cant sleep waiting for Saturday. Can you say DYNO!!!!!
[Re: JohnRR]
#1477943
08/14/13 11:02 AM
08/14/13 11:02 AM
Copper Dart
JohnRR, you are correct! Good call, that's exactly what was ordered. If I'm not mistaken, you know the builder. I know you ALL will approve ........... Saturday .... in the Dyno think it was the 17th of Aug ...........people......a man selling Icecream....
[Re: Copper Dart]
#1477944
08/14/13 11:13 AM
08/14/13 11:13 AM
Copper Dart
[Re: Copper Dart]
#1477945
08/14/13 12:15 PM
08/14/13 12:15 PM
Quicktree
Just noticed my "Cha-Ching-Cheapo" status At least someone with a sense of Humor ......I think ..... Dyno, Dyno
looks good tell elvis we said hi
[Re: Copper Dart]
#1477948
08/15/13 12:39 AM
08/15/13 12:39 AM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I run HS rockers, myself, and I'm happy with them (as many on this board have already told you, cheap rockers often end up costing you more in the end). But, I would recommend that your engine builder look over the rockers before installing. This isn't a knock against your builder - my HS rockers came with a lot of loose aluminum filings in the shaft, in the rockers, etc. HS makes good rockers, but they need to work on finishing their product, IMHO. Maybe they've improved this since I bought my rockers a couple of years ago. ...just trying to help.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
