STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES!
#1477869
08/01/13 08:11 PM
08/01/13 08:11 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I was just informed that there is a problem with the fit of the new Proform Roller rockers on my new 440 Source Stealth heads. I'm running a >.500 lift cam with 5/16 Pushrod. I was told roller tip to valve stem contact point is wrong and the heads will have to be clearanced to fit the pushrods. Something seems wrong. This is a new problem and is being investigated but I figured to post the issue for some feedback from you Motor Heads I must add that I'm confident that my builder will identify exactly what is the cause and the correct solution. It's got me a bit nervous that my Heart and my Pocket may not be able to handle the solution. Please help if you can. Thanks moparts!
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES!
[Re: Copper Dart]
#1477872
08/01/13 08:51 PM
08/01/13 08:51 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
grind back into the head/port side material to clearance pushrods . done it on both sets of 440 source heads I have .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#1477873
08/01/13 08:57 PM
08/01/13 08:57 PM
Copper Dart
Thanks for responding. What about the roller tips to valve stem issue?
[Re: Quicktree]
#1477876
08/01/13 09:06 PM
08/01/13 09:06 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
WELL YOU USED TWO OF THE CHEAPEST PIECES ON THE MARKET WHAT DID YOU EXPECT?
I was not going to go there ..
[Re: VernMotor]
#1477877
08/01/13 09:09 PM
08/01/13 09:09 PM
Quicktree
somebody has to be honest
[Re: topside]
#1477878
08/01/13 09:12 PM
08/01/13 09:12 PM
Copper Dart
Yes, custom ordered thick walled 5/16 with new adjusters ( pro forms were poorly made at the tip/ball end ). A complete pro valve job was done. I'm sure for you "season gear heads" it's no sweat but this is my first pro full build, blued, balanced and to be run in/Dyno'ed . It's like we're having a baby again, but this time I'm much more excited than my wife!
[Re: Dunnuck Racing]
#1477880
08/01/13 09:37 PM
08/01/13 09:37 PM
Copper Dart
I believe they can be returned. My pockets are near empty so witch ones to choose? Even with the refund, I believe I'll be spending another $300. +|-
[Re: Copper Dart]
#1477882
08/01/13 09:48 PM
08/01/13 09:48 PM
Posts: 3,396 Pa
Hot 340
Pa
You simply cannot imagine what even just one elcheapo part can do to set off an entire chain reaction of problems. That last time I helped someone with his engine he bought a few of these "bargain" parts and he ended up selling the car out of disgust. Buy good rockers.
[Re: topside]
#1477888
08/01/13 11:20 PM
08/01/13 11:20 PM
Copper Dart
With the custom length pushrods and adjuster tips already purchased (they cost a bit more than the rockers! ) I think staying with roller rockers is wise. If I knew it would become an issue, I might have opted to stick with the stock valve gear for my mild build. 20:20 Looks like a few have had good results with the 440 source heads. Confident enough to purchase them again! I hope mine turn out good too.
