Page 1 of 10 1 2 3 9 10
STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! #1477869
08/01/13 08:11 PM
08/01/13 08:11 PM
West Palm Beach, Florida
Copper Dart Offline OP
I was just informed that there is a problem with the fit of the new Proform Roller rockers on my new 440 Source Stealth heads.
I'm running a >.500 lift cam with 5/16 Pushrod.
I was told roller tip to valve stem contact point is wrong and the heads will have to be clearanced to fit the pushrods. Something seems wrong.
This is a new problem and is being investigated but I figured to post the issue for some feedback from you Motor Heads
I must add that I'm confident that my builder will identify exactly what is the cause and the correct solution.
It's got me a bit nervous that my Heart and my Pocket may not be able to handle the solution.
Please help if you can.
Thanks moparts!
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477870
08/01/13 08:46 PM
08/01/13 08:46 PM
ill
dennismopar73 Offline
ill
No worries, My RPMs had a simular issue, My engine builder said this is normal stuff comes into play once in a while,!!
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: dennismopar73] #1477871
08/01/13 08:48 PM
08/01/13 08:48 PM
What was the fix?
Mom.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477872
08/01/13 08:51 PM
08/01/13 08:51 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
grind back into the head/port side material to clearance pushrods . done it on both sets of 440 source heads I have .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: tex013] #1477873
08/01/13 08:57 PM
08/01/13 08:57 PM
Thanks for responding.
What about the roller tips to valve stem issue?
Mom.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477874
08/01/13 08:59 PM
08/01/13 08:59 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Opening up the pushrod holes is a pretty common tweak on Stealth heads, not a big deal - maybe 1 hour - though a bit of a disappointment. But I very rarely have anything go together without any effort. I can't comment on your rocker arms, but the Harland Sharps on mine were fine. Expect to need some improvement on the valve job. Your guy hopefully will check & optimize pushrod length.
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: topside] #1477875
08/01/13 09:05 PM
08/01/13 09:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
WELL YOU USED TWO OF THE CHEAPEST PIECES ON THE MARKET WHAT DID YOU EXPECT?
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Quicktree] #1477876
08/01/13 09:06 PM
08/01/13 09:06 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I was not going to go there ..
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: VernMotor] #1477877
08/01/13 09:09 PM
08/01/13 09:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
somebody has to be honest
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: topside] #1477878
08/01/13 09:12 PM
08/01/13 09:12 PM
Yes, custom ordered thick walled 5/16 with new adjusters ( pro forms were poorly made at the tip/ball end ). A complete pro valve job was done.
I'm sure for you "season gear heads" it's no sweat but this is my first pro full build, blued, balanced and to be run in/Dyno'ed .
It's like we're having a baby again, but this time I'm much more excited than my wife!
Mom.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477879
08/01/13 09:22 PM
08/01/13 09:22 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I hate to be the bearer of bad news,but I have a set of those Proform rocker arms that were falsely advertised as something else sitting here. They are too short to work properly on any cylinder head. Maybe your machinist knows something I don't on how to make them work but mine are paperweights.
Keith
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Dunnuck Racing] #1477880
08/01/13 09:37 PM
08/01/13 09:37 PM
I believe they can be returned.
My pockets are near empty so witch ones to choose?
Even with the refund, I believe I'll be spending another $300. +|-
Mom.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477881
08/01/13 09:47 PM
08/01/13 09:47 PM
Northern Indiana
Northern Indiana
I have used the Crane Gold rockers for years,but Hughes Engines has a similar priced set to them.
Keith
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477882
08/01/13 09:48 PM
08/01/13 09:48 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
You simply cannot imagine what even just one elcheapo part can do to set off an entire chain reaction of problems. That last time I helped someone with his engine he bought a few of these "bargain" parts and he ended up selling the car out of disgust. Buy good rockers.
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Hot 340] #1477883
08/01/13 10:00 PM
08/01/13 10:00 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Before you get depressed and hang yourself, clearancing for the pushrods should be a minimal expense. But prior to clearancing, you need the rockers you're going to use since the geometry may differ.
You don't need to go crazy on rockers. With only .500 lift, you could use just about any good rocker and they don't need to be rollers. The Crane or Isky nodular iron one's would work just fine with that cam if you could find a used set. I think Hughes has a reasonably priced roller.
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Quicktree] #1477884
08/01/13 10:01 PM
08/01/13 10:01 PM
I'm glad you felt it necessary to YELL that to me.
Am I mistaken that eddy's are made overseas too?
I am painting the heads and block to look like stock iron castings with a/c and wanted the advantage of aluminum heads. Not many choices out there guy.
I hope this doesn't turn into a nightmare but it was the best I could afford for my show car.
Mom.
Ricky Valdes
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: Copper Dart] #1477885
08/01/13 10:18 PM
08/01/13 10:18 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I wouldn't hesitate to run stock rockers on a .500 lift juice cam.
Mopar to the bone!!!
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: 72Swinger] #1477886
08/01/13 10:56 PM
08/01/13 10:56 PM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
http://www.ebay.com/itm/Mopar-383-413-42...978&vxp=mtr
I have a set of these on my 440. The adjusters needed to be replaced due to one of them breaking on the dyno, used T&D adjusters in my case. So far they're holding up well. The ones I had for my small block had hardness issues on the rollers and were falling apart. They had CAT cast into them and these on the 440 do not. I still have no doubt they're made in the same place but apparently got the roller hardness figured out finally. Mine's running approximately .500" lift at the valve as well. I recommend name brand springs on those 'Source heads. Haven't heard much good about the chinese made springs and dropping a valve can make a boat anchor out of a good engine really quick. Maybe you already have good springs, didn't catch it if you posted that. Good luck, hope you don't give up on the project, good things take time.
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: 72Swinger] #1477887
08/01/13 10:58 PM
08/01/13 10:58 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The Eddy heads on my other motor needed the same tweaking as the Stealths on my newest motor.
I've heard Crane Gold & Hughes are decent rocker arms, and I think 383man is running the 440Source or Hughes rockers; hopefully he'll chime in and correct me. I spend the extra $$ for HS because I've always had good experience with them, but that's overkill for your combo.
Re: STEALTH HEADS AND PROFORM ROLLER ROCKER ISSUES! [Re: topside] #1477888
08/01/13 11:20 PM
08/01/13 11:20 PM
With the custom length pushrods and adjuster tips already purchased (they cost a bit more than the rockers! ) I think staying with roller rockers is wise.
If I knew it would become an issue, I might have opted to stick with the stock valve gear for my mild build.
20:20
Looks like a few have had good results with the 440 source heads.
Confident enough to purchase them again! I hope mine turn out good too.
Mom.
Ricky Valdes
