Re: went edel victor aluminum head finaly!
[Re: Clanton]
#1347051
12/06/12 11:19 PM
12/06/12 11:19 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
The heads need all the work done to them so I have a way to go but thay are new ootb so if I can I will get some nice port work done.
[Re: Clanton]
#1347053
12/06/12 11:35 PM
12/06/12 11:35 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Nice stuff You giving them to Nick or Koffell's for the work? They should breath real nice with that huffer on top Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Clanton]
#1347056
12/06/12 11:51 PM
12/06/12 11:51 PM
fourgearsavoy
Rittman Ohio
I really don't think Nick does CNC porting I haven't been to the shop in about a year though and he adds new equipment all the time. It's usually just him and Bart with a die grinder and the flow bench Gus
[Re: Clanton]
#1347061
12/07/12 02:05 AM
12/07/12 02:05 AM
Thumperdart
State of confusion
NICE................ I`m going to ring out my rpm`s and go as quick as possible then step up to some max wedge anythings and see how much faster we can go. Should pick you up nicely w/the proper porting and valve job.
[Re: Clanton]
#1347070
12/08/12 01:43 PM
12/08/12 01:43 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
You could also have them hand ported instead of a one size fits all cnc port job. I know cnc is the trend nowadays but just something to think about...!
Brian Hafliger
[Re: Brian Hafliger]
#1347071
12/08/12 01:59 PM
12/08/12 01:59 PM
Clanton
northern,Ohio,USA
Thanks!I was thinking more on the hand porting and that is from a cost factor for now.
[Re: Clanton]
#1347072
12/08/12 07:51 PM
12/08/12 07:51 PM
Clanton
northern,Ohio,USA
I measured the bolt hole depth and I will be able to use the studs I have in there.SWEET! edelbrock outside .930 inside 1.030 middle 3.370
factory iron +/- .005 1.000 .975 3.040
[Re: Clanton]
#1347075
12/12/12 12:42 AM
12/12/12 12:42 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
Are those CFM measurements at .100 to .800 valve lift?
[Re: Cab_Burge]
#1347078
12/12/12 01:14 AM
12/12/12 01:14 AM
Clanton
northern,Ohio,USA
Yes
Well,Why do you ask ?LOL
[Re: Clanton]
#1347079
12/12/12 04:25 AM
12/12/12 04:25 AM
Cab_Burge
I was curious as to which numbers meant which numbers I'm assuming the second row is thw adapter use to flow at those numbers and the second line is the results in CFM, yes? Also what are the top numbers ?
[Re: tboomer]
#1347084
12/12/12 11:54 AM
12/12/12 11:54 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
I am watching this one! Are those the standard 77929 Victors out of the box? Mine started out as the standard port but were ported to MW size..I am thinking I went overkill on this!!
Ted, this word should not even be in your vocabulary
Go have some fun
Russ
[Re: Clanton]
#1347087
12/12/12 12:24 PM
12/12/12 12:24 PM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Clanton, So you are Boosting the motor? Try to raise the mid to upper lifts, the intake needs volume more than raw CFM and great exhaust efficiency is also important; that's what makes the Indy-1 with it's big Intake port and excellent raised exhaust a real natural for blower apps. You want to improve the exhaust to intake bias % since getting air IN is not an issue with boost, and for the powerband you're looking at...you don't want or need a ton of RPM since your torque band is going to be EPIC and roots blower efficency drops (heat) and tends to act as a big brake on the crank past its designed flow rate. Good heads and a relatively slow blower ratio really works great....if you get the cam and timing right it's almost unbeatable and VERY RELIABLE. I have the Chaoman stage VI's and the most impressive/important numbers are the mid lifts. Basically if you get your .400-.500 OOTB lift numbers to where your OOTB .500-.600 numbers are now and IMO you're all set. beyond that with the blower you just let the peak fall where they may beyond that. Cam selection will be critical, how big is the blower and what CID and static CR are you at. JE makes a nice blower/nitrous dish design. Run as long a rod as possible
Re: went edel victor aluminum head finaly!Flow tested.
[Re: Clanton]
#1347091
12/13/12 12:32 AM
12/13/12 12:32 AM
Clanton
northern,Ohio,USA
I would like a picture of a cnc exh port if anyone has 1 PLEASE! Thank you! I have a cutaway pic in stock form.
[Re: Clanton]
#1347092
12/13/12 12:44 AM
12/13/12 12:44 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Not sure if this we help you but this guy does some beautiful work. http://www.speierracingheads.com/BBMv3.3.htm
[Re: Jeremiah]
#1347094
12/13/12 01:34 PM
12/13/12 01:34 PM
Clanton
northern,Ohio,USA
Let me know if you want more pics.
Thank you!Do you have a pic from chamber side without the valve? What is the opening size on the exh exit? Thanks for the great pics,help!
[Re: Clanton]
#1347096
12/15/12 02:40 AM
12/15/12 02:40 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I had a chance to work on my engines today but forgot my camera. I'll get back to it Monday after work and get some pics for you.
[Re: hemi-itis]
#1347099
12/16/12 01:12 PM
12/16/12 01:12 PM
Clanton
northern,Ohio,USA
Your gunna need your COMP licence too
at least I dont need a dr note with the IHRAuntel 150mph I think.
[Re: hemi-itis]
#1347101
12/16/12 05:15 PM
12/16/12 05:15 PM
Clanton
northern,Ohio,USA
I guess I have been bored so I have been using the wallace calcs.Port speed will be 256 FPS[corrected] and the max velocity for that port csa/3.14 is 542fps at 6800 rpm.The gained cfm over my as working engine will be 70cfm with a hp rating anywhere from 1.4/2.0 hp per cfm N/A.The tune may change as far as fuel,timing but we will see.
[Re: Clanton]
#1347107
01/12/13 07:48 PM
01/12/13 07:48 PM
Clanton
northern,Ohio,USA
the final results are in. 1)77.76 2)149.49 3)209. 4)266.11 5)321.75 6)351.00 7)357.75 8)362.25
exh 1)63.50 2)108.50 3)153.45 4)194.06 5)219.10 6)225.36 7)228.49 8)225.36
all with factory size int,exh opening. Thank you Scott Koffel for the great work!
[Re: Clanton]
#1347115
01/13/13 12:59 PM
01/13/13 12:59 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
I am excited just to have finely got some aluminum heads.
I know the feeling, I was porting my own iron heads for years until 4 years ago when I scored some ported Indy SR's. Since then I've bought 2 sets of B1's, a set of Brad Anderson Hemi heads and I don't even have a hemi, and a chinese set of Victor copies.
[Re: Clanton]
#1347117
01/13/13 01:54 PM
01/13/13 01:54 PM
Posts: 16,928 NC
440Jim
NC
The ootb # are on page 1!
I put the numbers together in one place, for easy comparison.
[Re: 440Jim]
#1347118
01/13/13 04:32 PM
01/13/13 04:32 PM
Clanton
northern,Ohio,USA
I made it tough on Scott to make more cfm by limiting the port.The bowl,port,valve job needed done so I did what I could.The bigger change in those flow# is I did have 280int/180exh cfm and now the victor flow.
[Re: pittsburghracer]
#1347119
01/13/13 05:16 PM
01/13/13 05:16 PM
moparmanjames
Las Vegas NV
That is crazy isn't it. I started racing in the 70's and never had a set of aluminum heads till I was going thru a divorce in 1990. I bought a set of B1Bs heads and have been going strong ever since. Here's a small list. 1 set B1Bs 3 sets B1's 2 sets 440-1's 2 set 440source 12 sets small block edelbrock.
I keep saying it but these are GREAT times for us MOPAR racers.
Yep and with the price of machine work going up you might as well buy a new set of heads and just get whatever valve/spring combination you need for only a few bucks more. It's funny though, head prices are coming down but rocker arms (good ones) are going up.
[Re: Clanton]
#1347127
01/24/13 05:38 PM
01/24/13 05:38 PM
Clanton
northern,Ohio,USA
Well my headers fit just as good as the iron heads,my valve to piston without the .090 head gasket is .450 and the center of the int valve[.110] is .130 to the valve relief edge,the pushrod needs more clearence on the head by .100 tested at max lift with a std rocker and measuring to the perch where it runs on the iron head and subtracting the added .400 offset on the hs rocker they make for the victor head.
