Re: went edel victor aluminum head finaly!Flow tested.
[Re: Clanton]
#1347115
01/13/13 12:59 PM
01/13/13 12:59 PM
Posts: 1,260 Las Vegas NV
moparmanjames
Las Vegas NV
I am excited just to have finely got some aluminum heads.
I know the feeling, I was porting my own iron heads for years until 4 years ago when I scored some ported Indy SR's. Since then I've bought 2 sets of B1's, a set of Brad Anderson Hemi heads and I don't even have a hemi, and a chinese set of Victor copies.
[Re: Clanton]
#1347117
01/13/13 01:54 PM
01/13/13 01:54 PM
Posts: 16,936 NC
440Jim
NC
The ootb # are on page 1!
I put the numbers together in one place, for easy comparison.
[Re: 440Jim]
#1347118
01/13/13 04:32 PM
01/13/13 04:32 PM
Posts: 4,492 northern,Ohio,USA
Clanton
northern,Ohio,USA
I made it tough on Scott to make more cfm by limiting the port.The bowl,port,valve job needed done so I did what I could.The bigger change in those flow# is I did have 280int/180exh cfm and now the victor flow.
[Re: pittsburghracer]
#1347119
01/13/13 05:16 PM
01/13/13 05:16 PM
moparmanjames
Las Vegas NV
That is crazy isn't it. I started racing in the 70's and never had a set of aluminum heads till I was going thru a divorce in 1990. I bought a set of B1Bs heads and have been going strong ever since. Here's a small list. 1 set B1Bs 3 sets B1's 2 sets 440-1's 2 set 440source 12 sets small block edelbrock.
I keep saying it but these are GREAT times for us MOPAR racers.
Yep and with the price of machine work going up you might as well buy a new set of heads and just get whatever valve/spring combination you need for only a few bucks more. It's funny though, head prices are coming down but rocker arms (good ones) are going up.
[Re: Clanton]
#1347127
01/24/13 05:38 PM
01/24/13 05:38 PM
Clanton
northern,Ohio,USA
Well my headers fit just as good as the iron heads,my valve to piston without the .090 head gasket is .450 and the center of the int valve[.110] is .130 to the valve relief edge,the pushrod needs more clearence on the head by .100 tested at max lift with a std rocker and measuring to the perch where it runs on the iron head and subtracting the added .400 offset on the hs rocker they make for the victor head.
