Page 2 of 4 1 2 3 4
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347070
12/08/12 01:43 PM
12/08/12 01:43 PM
SoCal
Brian Hafliger Offline
SoCal
You could also have them hand ported instead of a one size fits all cnc port job.
I know cnc is the trend nowadays but just something to think about...!
Brian Hafliger
Re: went edel victor aluminum head finaly! [Re: Brian Hafliger] #1347071
12/08/12 01:59 PM
12/08/12 01:59 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks!I was thinking more on the hand porting and that is from a cost factor for now.
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347072
12/08/12 07:51 PM
12/08/12 07:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I measured the bolt hole depth and I will be able to use the studs I have in there.SWEET!
edelbrock
outside .930
inside 1.030
middle 3.370
factory iron +/- .005
1.000
.975
3.040
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347073
12/11/12 08:49 PM
12/11/12 08:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got the heads flowed.This is OOTB!
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347074
12/11/12 08:55 PM
12/11/12 08:55 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
That exhaust is going to need some work
Hope to see these perform next year
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347075
12/12/12 12:42 AM
12/12/12 12:42 AM
Are those CFM measurements at .100 to .800 valve lift?
Re: went edel victor aluminum head finaly! [Re: Cab_Burge] #1347076
12/12/12 12:44 AM
12/12/12 12:44 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Yes
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347077
12/12/12 01:02 AM
12/12/12 01:02 AM
Yes
Re: went edel victor aluminum head finaly! [Re: Cab_Burge] #1347078
12/12/12 01:14 AM
12/12/12 01:14 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Yes
Well,Why do you ask ?LOL
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347079
12/12/12 04:25 AM
12/12/12 04:25 AM
I was curious as to which numbers meant which numbers I'm assuming the second row is thw adapter use to flow at those numbers and the second line is the results in CFM, yes? Also what are the top numbers ?
Re: went edel victor aluminum head finaly! [Re: Cab_Burge] #1347080
12/12/12 11:09 AM
12/12/12 11:09 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Look like port dimensions to me
Re: went edel victor aluminum head finaly! [Re: roadhazard] #1347081
12/12/12 11:24 AM
12/12/12 11:24 AM
tboomer Online work
tboomer  Online Work
I am watching this one! Are those the standard 77929 Victors out of the box? Mine started out as the standard port but were ported to MW size..I am thinking I went overkill on this!!
Re: went edel victor aluminum head finaly! [Re: tboomer] #1347082
12/12/12 11:43 AM
12/12/12 11:43 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
the heads are 77929.
1st # lift,2nd is flow range,3rd is flow in that range and last is calculated flow.
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347083
12/12/12 11:45 AM
12/12/12 11:45 AM
tboomer Online work
tboomer  Online Work
Thanks! Now I know I screwed up...Should have just did the essentials and saved a buttload of money...
Re: went edel victor aluminum head finaly! [Re: tboomer] #1347084
12/12/12 11:54 AM
12/12/12 11:54 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Ted, this word should not even be in your vocabulary
Go have some fun
Russ
Re: went edel victor aluminum head finaly! [Re: tboomer] #1347085
12/12/12 11:55 AM
12/12/12 11:55 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Those #s look higher on the intake and lower on the exhaust than I've seen for other OOB 77929 heads, so I'm not sure how comparable they are to the rest of the data I've seen for that model of head.
Re: went edel victor aluminum head finaly! [Re: BradH] #1347086
12/12/12 12:09 PM
12/12/12 12:09 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
In the long run they are just #'s to start with and a big improvement over my iron heads and for me a very big move to make that I have waited to do for a long time so I am happy to say the least.
Re: went edel victor aluminum head finaly! [Re: Clanton] #1347087
12/12/12 12:24 PM
12/12/12 12:24 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Clanton,
So you are Boosting the motor? Try to raise the mid to upper lifts, the intake needs volume more than raw CFM and great exhaust efficiency is also important; that's what makes the Indy-1 with it's big Intake port and excellent raised exhaust a real natural for blower apps. You want to improve the exhaust to intake bias % since getting air IN is not an issue with boost, and for the powerband you're looking at...you don't want or need a ton of RPM since your torque band is going to be EPIC and roots blower efficency drops (heat) and tends to act as a big brake on the crank past its designed flow rate. Good heads and a relatively slow blower ratio really works great....if you get the cam and timing right it's almost unbeatable and VERY RELIABLE.
I have the Chaoman stage VI's and the most impressive/important numbers are the mid lifts. Basically if you get your .400-.500 OOTB lift numbers to where your OOTB .500-.600 numbers are now and IMO you're all set. beyond that with the blower you just let the peak fall where they may beyond that. Cam selection will be critical, how big is the blower and what CID and static CR are you at. JE makes a nice blower/nitrous dish design. Run as long a rod as possible
WIZE
In Car:
Re: went edel victor aluminum head finaly! [Re: Streetwize] #1347088
12/12/12 12:38 PM
12/12/12 12:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Yes the engine has a roots blower/carbs.The casting is rough around the valves and will improve a bunch in the low/mid range cleaning the chamber up and throat.The test bore size will help/hurt flow also so maybe it was done with a larger bore tube.The engine is a 446 3.75 stroke,9.4cr with the heads haveing a choke of 3.14sq.in. with 6800 rpm,.630/112lsa cam so I am sure my port air speed will be fine.
Re: went edel victor aluminum head finaly! [Re: tboomer] #1347089
12/12/12 01:47 PM
12/12/12 01:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Look at the advertised flow here.
http://www.edelbrock.com/automotive_new/mc/cylheads/chrysler/bb_victor.shtml
and mine is not that far off.
Page 2 of 4 1 2 3 4
