Page 4 of 4 1 2 3 4
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347110
01/12/13 09:57 PM
01/12/13 09:57 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
The ootb # are on page 1!
Sorry about that. I forgot about your earlier post with the before numbers. Looks like they stack up real nice against a ported 440-1 head. Do they come with a max wedge intake port Out of the box?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: pittsburghracer] #1347111
01/12/13 10:12 PM
01/12/13 10:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There is a MW port in this head offered ootb.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347112
01/13/13 09:43 AM
01/13/13 09:43 AM
tboomer Offline
tboomer  Offline
Pretty good numbers! I will post my flow sheet when I get it. It will be interesting as we both started with the same 77929 heads. Radar Lechtenberg did mine and he also said he never saw a flow bench win a race yet!!
Re: went edel victor aluminum head finaly!Flow tested. [Re: tboomer] #1347113
01/13/13 11:28 AM
01/13/13 11:28 AM
PA.
"Little"John
"Little"John
PA.
Very true Ted but a flow bench can help you get to the finish line first.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: tboomer] #1347114
01/13/13 12:41 PM
01/13/13 12:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am excited just to have finely got some aluminum heads.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347115
01/13/13 12:59 PM
01/13/13 12:59 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
I know the feeling, I was porting my own iron heads for years until 4 years ago when I scored some ported Indy SR's. Since then I've bought 2 sets of B1's, a set of Brad Anderson Hemi heads and I don't even have a hemi, and a chinese set of Victor copies.
Re: went edel victor aluminum head finaly!Flow tested. [Re: moparmanjames] #1347116
01/13/13 01:11 PM
01/13/13 01:11 PM
PA.
"Little"John
"Little"John
PA.
That is crazy isn't it. I started racing in the 70's and never had a set of aluminum heads till I was going thru a divorce in 1990. I bought a set of B1Bs heads and have been going strong ever since. Here's a small list.
1 set B1Bs
3 sets B1's
2 sets 440-1's
2 set 440source
12 sets small block edelbrock.
I keep saying it but these are GREAT times for us MOPAR racers.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347117
01/13/13 01:54 PM
01/13/13 01:54 PM
NC
440Jim Offline
440Jim  Offline
NC
I put the numbers together in one place, for easy comparison.
Re: went edel victor aluminum head finaly!Flow tested. [Re: 440Jim] #1347118
01/13/13 04:32 PM
01/13/13 04:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I made it tough on Scott to make more cfm by limiting the port.The bowl,port,valve job needed done so I did what I could.The bigger change in those flow# is I did have 280int/180exh cfm and now the victor flow.
Re: went edel victor aluminum head finaly!Flow tested. [Re: pittsburghracer] #1347119
01/13/13 05:16 PM
01/13/13 05:16 PM
Las Vegas NV
Las Vegas NV
1 set B1Bs
3 sets B1's
2 sets 440-1's
2 set 440source
Yep and with the price of machine work going up you might as well buy a new set of heads and just get whatever valve/spring combination you need for only a few bucks more.
It's funny though, head prices are coming down but rocker arms (good ones) are going up.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347120
01/21/13 05:00 PM
01/21/13 05:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I called wiseco about my valve relief size in the piston because the Victors have 2.20 valves and the good news is the reliefs in the K373A3 pistons are 2.350 and .190 deep and I wont have to take the pistons out to do work for that.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347121
01/24/13 01:45 AM
01/24/13 01:45 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got the heads back and they look AWSOME!Thank you Scott for going over the details with me and tech info!
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347122
01/24/13 01:46 AM
01/24/13 01:46 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
exh
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347123
01/24/13 01:47 AM
01/24/13 01:47 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
bowls
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347124
01/24/13 01:48 AM
01/24/13 01:48 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I bowl
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347125
01/24/13 01:52 AM
01/24/13 01:52 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
o ring,chamber
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347126
01/24/13 12:29 PM
01/24/13 12:29 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I can progress to a bunch of things from push rod checking to intake,header mock up so over time get some and grab a
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347127
01/24/13 05:38 PM
01/24/13 05:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Well my headers fit just as good as the iron heads,my valve to piston without the .090 head gasket is .450 and the center of the int valve[.110] is .130 to the valve relief edge,the pushrod needs more clearence on the head by .100 tested at max lift with a std rocker and measuring to the perch where it runs on the iron head and subtracting the added .400 offset on the hs rocker they make for the victor head.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347128
01/24/13 05:50 PM
01/24/13 05:50 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
here is the old headers bolted up.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347129
01/24/13 05:53 PM
01/24/13 05:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The valve covers fit nice but are close to the rockers.
Page 4 of 4 1 2 3 4
