Page 3 of 4 1 2 3 4
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347090
12/12/12 02:19 PM
12/12/12 02:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
here are some good cutaway pics of the ports and how much they can be opened.
http://www.moparmusclemagazine.com/techarticles/engine/mopp_0804_edelbrock_victor_440/viewall.html
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347091
12/13/12 12:32 AM
12/13/12 12:32 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I would like a picture of a cnc exh port if anyone has 1 PLEASE!
Thank you!
I have a cutaway pic in stock form.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347092
12/13/12 12:44 AM
12/13/12 12:44 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Not sure if this we help you but this guy does some beautiful work.
http://www.speierracingheads.com/BBMv3.3.htm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: pittsburghracer] #1347093
12/13/12 11:54 AM
12/13/12 11:54 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Let me know if you want more pics.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Jeremiah] #1347094
12/13/12 01:34 PM
12/13/12 01:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you!Do you have a pic from chamber side without the valve?
What is the opening size on the exh exit?
Thanks for the great pics,help!
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347095
12/14/12 08:15 PM
12/14/12 08:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My static CR at this time with the closed chamber head change is 9.28 and dynamic of about 7.7
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347096
12/15/12 02:40 AM
12/15/12 02:40 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I had a chance to work on my engines today but forgot my camera. I'll get back to it Monday after work and get some pics for you.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Jeremiah] #1347097
12/15/12 10:38 AM
12/15/12 10:38 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks I appreciate you taking the time to do so! Good luck with your engines.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347098
12/16/12 12:55 PM
12/16/12 12:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Your gunna need your COMP licence too
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: went edel victor aluminum head finaly!Flow tested. [Re: hemi-itis] #1347099
12/16/12 01:12 PM
12/16/12 01:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
at least I dont need a dr note with the IHRAuntel 150mph I think.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347100
12/16/12 03:33 PM
12/16/12 03:33 PM
hemi-itis Offline
hemi-itis  Offline
I don't even know where the closest IHRA track is to me
Re: went edel victor aluminum head finaly!Flow tested. [Re: hemi-itis] #1347101
12/16/12 05:15 PM
12/16/12 05:15 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I guess I have been bored so I have been using the wallace calcs.Port speed will be 256 FPS[corrected] and the max velocity for that port csa/3.14 is 542fps at 6800 rpm.The gained cfm over my as working engine will be 70cfm with a hp rating anywhere from 1.4/2.0 hp per cfm N/A.The tune may change as far as fuel,timing but we will see.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347102
01/03/13 04:16 PM
01/03/13 04:16 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want to thank Koffels place for performing awsome work on my heads giving me performance I had only dreamed of from a std port opening.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347103
01/03/13 04:27 PM
01/03/13 04:27 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
You going to post some numbers Mike?
Let's see the sheet
Re: went edel victor aluminum head finaly!Flow tested. [Re: roadhazard] #1347104
01/03/13 04:33 PM
01/03/13 04:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The #'s are very good and when they are done all the way I will post them.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347105
01/03/13 05:15 PM
01/03/13 05:15 PM
PA.
"Little"John
"Little"John
PA.
Please give us before and after numbers from the same bench. Those are the ones that count.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: pittsburghracer] #1347106
01/03/13 06:13 PM
01/03/13 06:13 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
^They are.
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347107
01/12/13 07:48 PM
01/12/13 07:48 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
the final results are in.
1)77.76
2)149.49
3)209.
4)266.11
5)321.75
6)351.00
7)357.75
8)362.25
exh
1)63.50
2)108.50
3)153.45
4)194.06
5)219.10
6)225.36
7)228.49
8)225.36
all with factory size int,exh opening.
Thank you Scott Koffel for the great work!
Re: went edel victor aluminum head finaly!Flow tested. [Re: Clanton] #1347108
01/12/13 08:50 PM
01/12/13 08:50 PM
PA.
"Little"John
"Little"John
PA.
1)77.76
2)149.49
3)209.
4)266.11
5)321.75
6)351.00
7)357.75
8)362.25
exh
1)63.50
2)108.50
3)153.45
4)194.06
5)219.10
6)225.36
7)228.49
8)225.36
Did he give you the before numbers. To me they are as important as the final numbers and gives you a better comparison of how accurate a persons bench is. Lots of shops don't like to do that and its usually for a good reason.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: went edel victor aluminum head finaly!Flow tested. [Re: pittsburghracer] #1347109
01/12/13 09:19 PM
01/12/13 09:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The ootb # are on page 1!
Page 3 of 4 1 2 3 4
