Need photo 70 E-Body Backside of Dash Please.
#117800
09/09/08 10:51 AM
09/09/08 10:51 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
I have searched (because I know this has been requested before) but can not find the thread or photo.
I have basically completed the Dash Resto of my 70 Challenger and I am doing the final check to make sure that I have everything routed and positioned correctly. I would appreciate if someone could post a full photo of the back side for reference.
Thank you..I would appreciate it.
Joe
65 Barracuda 70 Challenger
Re: Need photo 70 E-Body Backside of Dash Please.
[Re: screamindriver]
#117802
09/09/08 01:29 PM
09/09/08 01:29 PM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
Thanks. Now, I know that 1/2 of what I have is right. ![](/ubbthreads/images/graemlins/laugh2.gif) The previous owner added the "c. light" group to the car. I found some suspect spots that harness and am not going to use it. I am going to use the glovebox light though. Can it go into the same orange feed that feeds the gauge lights and the cigarette lighter bulb or should it plug in elsewhere? Based on the photo above it looks like it may go into the 3 way pink plug. Thanks, Joe
[Re: Snoopy]
#117811
09/09/08 05:13 PM
09/09/08 05:13 PM
Posts: 350 Hudson Valley
conv440
Hudson Valley
It was part of the A01 option package. If your fender tag doesn't list A01, it's not used.
Cool, so if you install the A01 wire harness you get the headlight buzzer? I just picked one up on e-gag. I know I'm thread hijacking, sorry, but I can't count the number of times I've left the lights on and killed the battery.
[Re: conv440]
#117812
09/09/08 05:25 PM
09/09/08 05:25 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
A01 = Light Package: Glove Box Lock, Map/Courtesy Light, Reading And Dome Light, Glove Box Light, Ash Receiver Light, Trunk Compartment Light, Hood/Fender Turn Signal Lights, Ignition Switch Light With Timer, Headlight On Buzzer And Headlight Switch Light With Timer.
[Re: jrwoodjoe]
#117814
09/09/08 07:27 PM
09/09/08 07:27 PM
Snoopy
Snoopy, for some reason the last PDF attachments will not download. The first 2 you did downloaded fine.
Joe, I just tried them and they work. Try right clicking on the attachment and either save target or print target.
[Re: jrwoodjoe]
#117817
09/10/08 07:35 AM
09/10/08 07:35 AM
Posts: 4,105 Horsham, Pa.
Finoke
Horsham, Pa.
I tried save target and get error messages when I try to open them. Maybe it's an acrobat version problem. I'll have to look into it further I guess.
Thanks, Joe
Joe, I'm glad to see your working hard. My car finally made it to the body shop. Hopefully I will be reassembling this winter.
Any pictures of how the dash is turning out???
Tom
[Re: jrwoodjoe]
#117819
09/10/08 11:10 AM
09/10/08 11:10 AM
Finoke
Horsham, Pa.
Tom
Hey Tom!
Yes, I'm getting some things done and it's good therapy and stress relief. It has been a hard spring/summer with our infant. She will not eat or drink and the Dr.s do not know why and are baffled. Healthy and normal in every way but just wont' eat or drink. Since late April, she has to have her feedings via feeding tube so that she will maintain her weight. She is being sent to Vanderilt shortly to see if they can figure out what the problem might be.
The dash is facing a wall so that I can finish up the wiring so it's hard to get a photo of the front right now. Here is a photo that I took a week or two ago of it before it had the speakers mounted, lower trim and glovebox installed.
I hope to start on the Heaterbox resto this weekend.
Can't wait to see your project...I need some pics for motivation buddy. ![](/ubbthreads/images/graemlins/scope.gif)
Joe
Joe, Sorry to hear that your daughter is having problems. I was hoping that all is well. Hopefully the specialist will find something, then get her on to the road to recovery! I'll will keep her in my prayers.
On a lighter note, I know what you mean about restoration being good for your own state of mind. I do it all the time ![](/ubbthreads/images/graemlins/grin.gif)
Your dash looks great! I'll post a pic of mine.......
