Page 1 of 10 1 2 3 9 10
Need photo 70 E-Body Backside of Dash Please. #117800
09/09/08 10:51 AM
09/09/08 10:51 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
I have searched (because I know this has been requested before) but can not find the thread or photo.
I have basically completed the Dash Resto of my 70 Challenger and I am doing the final check to make sure that I have everything routed and positioned correctly. I would appreciate if someone could post a full photo of the back side for reference.
Thank you..I would appreciate it.
Joe
65 Barracuda
70 Challenger
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117801
09/09/08 12:47 PM
09/09/08 12:47 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Here's a partial pic that comes up occasionally... Now all you need is a pic of the left side...
Re: Need photo 70 E-Body Backside of Dash Please. [Re: screamindriver] #117802
09/09/08 01:29 PM
09/09/08 01:29 PM
Tenn.
Tenn.
Thanks. Now, I know that 1/2 of what I have is right.
The previous owner added the "c. light" group to the car. I found some suspect spots that harness and am not going to use it. I am going to use the glovebox light though. Can it go into the same orange feed that feeds the gauge lights and the cigarette lighter bulb or should it plug in elsewhere? Based on the photo above it looks like it may go into the 3 way pink plug.
Thanks, Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117803
09/09/08 01:33 PM
09/09/08 01:33 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The information you need is in the factory service manual.
This is for a 70 Barracuda and is from the 70 Plymouth Service Manual.
Part 1
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117804
09/09/08 01:34 PM
09/09/08 01:34 PM
Snoopy Offline
Snoopy  Offline
Part 2
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117805
09/09/08 03:05 PM
09/09/08 03:05 PM
Tenn.
Tenn.
Thanks Snoopy. Those were helpful. I think I have everything correct. Didn't see the glove box light wiring and I don't have it in any of my stuff. That is the only thing I'm not sure about.
Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117806
09/09/08 04:14 PM
09/09/08 04:14 PM
Snoopy Offline
Snoopy  Offline
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117807
09/09/08 04:15 PM
09/09/08 04:15 PM
Snoopy Offline
Snoopy  Offline
2
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117808
09/09/08 04:20 PM
09/09/08 04:20 PM
Hudson Valley
conv440 Offline
conv440  Offline
Hudson Valley
In the pix above it shows the 'key in' buzzer but it also lists it as a 'headlight on' relay. Did E bodys have a headlight on buzzer for when you leave the lights on and open the door? I know my 70 Challenger does not. AMHIK.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: conv440] #117809
09/09/08 04:29 PM
09/09/08 04:29 PM
Snoopy Offline
Snoopy  Offline
It was part of the A01 option package.
If your fender tag doesn't list A01, it's not used.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117810
09/09/08 05:08 PM
09/09/08 05:08 PM
Ft. Worth, TX
TransAm Twins Offline
Ft. Worth, TX
Joe
What paint did you wind up using on the dash frame. glove box lid, and ashttray lid? Knew you were having issues at the time.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117811
09/09/08 05:13 PM
09/09/08 05:13 PM
Hudson Valley
conv440 Offline
conv440  Offline
Hudson Valley
Cool, so if you install the A01 wire harness you get the headlight buzzer? I just picked one up on e-gag. I know I'm thread hijacking, sorry, but I can't count the number of times I've left the lights on and killed the battery.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: conv440] #117812
09/09/08 05:25 PM
09/09/08 05:25 PM
Snoopy Offline
Snoopy  Offline
A01 = Light Package:
Glove Box Lock, Map/Courtesy Light, Reading And Dome Light, Glove Box Light, Ash Receiver Light, Trunk Compartment Light, Hood/Fender Turn Signal Lights, Ignition Switch Light With Timer, Headlight On Buzzer And Headlight Switch Light With Timer.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: TransAm Twins] #117813
09/09/08 07:21 PM
09/09/08 07:21 PM
Tenn.
Tenn.
Snoopy, for some reason the last PDF attachments will not download. The first 2 you did downloaded fine.
Joe
I used the Textured Paint as mentioned in the other thread. It looks very nice but is not perfect. There is a a little more texture than should be. If I were to do it again, I would knock it down a little more and use a Satin Black over the top. Best solution would be to use Prof Spray gun and correct paint. I just don't have those tools or skills. For a car that will be a VERY NICE occasional driver, it is fine.
Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117814
09/09/08 07:27 PM
09/09/08 07:27 PM
Snoopy Offline
Snoopy  Offline
Joe,
I just tried them and they work. Try right clicking on the attachment and either save target or print target.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Snoopy] #117815
09/09/08 07:45 PM
09/09/08 07:45 PM
Tenn.
Tenn.
I tried save target and get error messages when I try to open them. Maybe it's an acrobat version problem. I'll have to look into it further I guess.
Thanks, Joe
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117816
09/09/08 07:49 PM
09/09/08 07:49 PM
Snoopy Offline
Snoopy  Offline
You may need Adobe Reader 7 or higher to view.
Adobe Reader 9
If you don't want the Google Toolbar, make sure you uncheck it.
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117817
09/10/08 07:35 AM
09/10/08 07:35 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Thanks, Joe
Joe,
I'm glad to see your working hard. My car finally made it to the body shop. Hopefully I will be reassembling this winter.
Any pictures of how the dash is turning out???
Tom
Re: Need photo 70 E-Body Backside of Dash Please. [Re: Finoke] #117818
09/10/08 10:06 AM
09/10/08 10:06 AM
Tenn.
Tenn.
Joe,
Tom
Hey Tom!
Yes, I'm getting some things done and it's good therapy and stress relief. It has been a hard spring/summer with our infant. She will not eat or drink and the Dr.s do not know why and are baffled. Healthy and normal in every way but just wont' eat or drink. Since late April, she has to have her feedings via feeding tube so that she will maintain her weight. She is being sent to Vanderilt shortly to see if they can figure out what the problem might be.
The dash is facing a wall so that I can finish up the wiring so it's hard to get a photo of the front right now. Here is a photo that I took a week or two ago of it before it had the speakers mounted, lower trim and glovebox installed.
I hope to start on the Heaterbox resto this weekend.
Can't wait to see your project...I need some pics for motivation buddy.
Joe
65 Barracuda
70 Challenger
Re: Need photo 70 E-Body Backside of Dash Please. [Re: jrwoodjoe] #117819
09/10/08 11:10 AM
09/10/08 11:10 AM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
Joe,
Tom
Hey Tom!
Joe
Joe,
Sorry to hear that your daughter is having problems. I was hoping that all is well. Hopefully the specialist will find something, then get her on to the road to recovery! I'll will keep her in my prayers.
On a lighter note, I know what you mean about restoration being good for your own state of mind. I do it all the time
Your dash looks great! I'll post a pic of mine.......
