Re: explain 70 440 4bbl oval air cleaners w/air grabber
[Re: 1_WILD_RT]
#112125
08/31/08 09:46 PM
08/31/08 09:46 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
As stated previously just set the base on a flat surface & if it stands with only the carb throat area touching it's a 383 unit, if the front lip of the baseplate touches it's for a 440...Your lid is definately for a 69...
Sometimes the simple approach just isn't good enough.
Re: explain 70 440 4bbl oval air cleaners w/air grabber..
[Re: SleeperBee]
#112127
08/31/08 10:30 PM
08/31/08 10:30 PM
Posts: 75,078 U.S.S.A.
JohnRR
U.S.S.A.
I would be surprised if you find one under $500. It seems like everyone who has one knows how rare it is. . . . but the scavenger hunt is part of the fun! I have seen a few in MGC and some of the swap meets. They are out there!
Ben Snobar sells a repop for both the 383 and the 440 air cleaner for a 69. With that in mind I wouldn't pay much more for one unless it was basicly NOS in condition than what the repop sells for .
[Re: cataclysm80]
#112128
08/31/08 10:31 PM
08/31/08 10:31 PM
JohnRR
U.S.S.A.
I've heard this lid decal is for 69 cars. ?????
Tav
Tav , thats an UGLY looking 69 air cleaner assembly .
[Re: cataclysm80]
#112129
08/31/08 10:33 PM
08/31/08 10:33 PM
JohnRR
U.S.S.A.
here's a pic of the hood. You can see the 440 emblem at the bottom right of the pic.
car is a 70 roadrunner 383 4 speed plum crazy without N96 on the fender tag.
hood was on the car when I got it and is copper colored on the bottom. this is a 70 only hood right?
The pictured air cleaner was in the trunk.
the engine in the car was a 400 2 bbl
So, what do I have here?
Tav
Yes thats a 70 ONLY air grabber hood , you have the wrong air cleaner considering what Tony posted about the height difference.
[Re: JohnRR]
#112132
09/01/08 07:38 AM
09/01/08 07:38 AM
Posts: 4,165 Florida
cataclysm80
I see what your saying. My 69 383 air cleaner is a full inch taller than the 70 model I need. Can my 69 baseplate be trimmed/made to fit or should I be looking for the correct piece?
If I use the correct decal, is my air cleaner lid correct for a 70?
Tav
[Re: quick77rt ]
#112137
09/01/08 03:37 PM
09/01/08 03:37 PM
JohnRR
U.S.S.A.
Ive one from my old 71 440 R/T charger with AG hood...are these the same or diff from the 70 440 setup?
yes , it's the same
[Re: meepmeep70]
#112138
09/01/08 03:40 PM
09/01/08 03:40 PM
JohnRR
U.S.S.A.
hard to find! also looking for the correct 70 air grabber air cleaner set-up,haven't found one yet good luck
looks like the 70 up base is NOT repopped, just the lid is .
Re: 70 440 4bbl oval baseplate with round lid
[Re: 70stroker]
#112140
11/03/08 09:05 AM
11/03/08 09:05 AM
JohnRR
U.S.S.A.
Here are pics of the baseplate I have. It is for the 1970-72 air grabber setup. Pics show the measurements. None of the measurements match anything posted for the front or rear lips or the carb horn to crossbar. It appears Tony's measurements would be close and make this a 383 piece. If you have any pics of the 440 baseplate for a `70-`72, please post them for comparison.
Lets see a pic of the carb mount surface , maybe it's been modified ?
[Re: 1fastrunner]
#112142
11/03/08 12:00 PM
11/03/08 12:00 PM
JohnRR
U.S.S.A.
Here's a picture of a 440 base with measurement. Note, when placed on a flat surface without the drain hose, the round part that would sit on the carb is suspended slightly above the surface.
That's a small picture
