Page 2 of 3 1 2 3
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: 1_WILD_RT] #112125
08/31/08 09:46 PM
08/31/08 09:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
As stated previously just set the base on a flat surface & if it stands with only the carb throat area touching it's a 383 unit, if the front lip of the baseplate touches it's for a 440...Your lid is definately for a 69...
Sometimes the simple approach just isn't good enough.
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: nutso suave] #112126
08/31/08 09:55 PM
08/31/08 09:55 PM
Scat City, USA
SleeperBee Offline
SleeperBee  Offline
Scat City, USA
I would be surprised if you find one under $500. It seems like everyone who has one knows how rare it is. . . . but the scavenger hunt is part of the fun! I have seen a few in MGC and some of the swap meets. They are out there!
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: SleeperBee] #112127
08/31/08 10:30 PM
08/31/08 10:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ben Snobar sells a repop for both the 383 and the 440 air cleaner for a 69. With that in mind I wouldn't pay much more for one unless it was basicly NOS in condition than what the repop sells for .
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112128
08/31/08 10:31 PM
08/31/08 10:31 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I've heard this lid decal is for 69 cars. ?????
Tav
Tav , thats an UGLY looking 69 air cleaner assembly .
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: cataclysm80] #112129
08/31/08 10:33 PM
08/31/08 10:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
here's a pic of the hood. You can see the 440 emblem at the bottom right of the pic.
car is a 70 roadrunner 383 4 speed plum crazy without N96 on the fender tag.
hood was on the car when I got it and is copper colored on the bottom. this is a 70 only hood right?
The pictured air cleaner was in the trunk.
the engine in the car was a 400 2 bbl
So, what do I have here?
Tav
Yes thats a 70 ONLY air grabber hood , you have the wrong air cleaner considering what Tony posted about the height difference.
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: SleeperBee] #112130
08/31/08 10:37 PM
08/31/08 10:37 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I saw plenty at The Nats for $400 and UP. any where from ready to slap on or needind striped and redone.
I want one, just can't justify it when I have new 1/4s laying in the garage.
1981 Dodge D150 360 auto
Re: explain 70 440 4bbl oval air cleaners w/air grabber.. [Re: basketcase] #112131
08/31/08 11:24 PM
08/31/08 11:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Here's mine, someone cut the front to clear a a/c unit .
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: JohnRR] #112132
09/01/08 07:38 AM
09/01/08 07:38 AM
cataclysm80 Offline
cataclysm80  Offline
I see what your saying. My 69 383 air cleaner is a full inch taller than the 70 model I need. Can my 69 baseplate be trimmed/made to fit or should I be looking for the correct piece?
If I use the correct decal, is my air cleaner lid correct for a 70?
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: cataclysm80] #112133
09/01/08 08:17 AM
09/01/08 08:17 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Tav
I would find the correct base as the lid you have is INCORRECT for 1970 , 1970 used a ROUND filter with a round lid on an OVAL base , the base has water drains ahead of the filter.
here is what you are looking for , thanks Nick .
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: JohnRR] #112134
09/01/08 09:40 AM
09/01/08 09:40 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Ive one from my old 71 440 R/T charger with AG hood...are these the same or diff from the 70 440 setup?
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: quick77rt ] #112135
09/01/08 10:07 AM
09/01/08 10:07 AM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
hard to find! also looking for the correct 70 air grabber air cleaner set-up,haven't found one yet good luck
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: meepmeep70] #112136
09/01/08 12:22 PM
09/01/08 12:22 PM
cataclysm80 Offline
cataclysm80  Offline
Thanks for the pic, that helps a lot!
Tav
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: quick77rt ] #112137
09/01/08 03:37 PM
09/01/08 03:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes , it's the same
Re: explain 70 440 4bbl oval air cleaners w/air grabber [Re: meepmeep70] #112138
09/01/08 03:40 PM
09/01/08 03:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
looks like the 70 up base is NOT repopped, just the lid is .
70 440 4bbl oval baseplate with round lid [Re: JohnRR] #112139
11/02/08 11:20 PM
11/02/08 11:20 PM
FL
70stroker Offline
70stroker  Offline
FL
Here are pics of the baseplate I have. It is for the 1970-72 air grabber setup. Pics show the measurements. None of the measurements match anything posted for the front or rear lips or the carb horn to crossbar.
It appears Tony's measurements would be close and make this a 383 piece. If you have any pics of the 440 baseplate for a `70-`72, please post them for comparison.
Re: 70 440 4bbl oval baseplate with round lid [Re: 70stroker] #112140
11/03/08 09:05 AM
11/03/08 09:05 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Lets see a pic of the carb mount surface , maybe it's been modified ?
Re: 70 440 4bbl oval baseplate with round lid [Re: JohnRR] #112141
11/03/08 10:55 AM
11/03/08 10:55 AM
Hunt Valley, Maryland
1fastrunner Offline
1fastrunner  Offline
Here's a picture of a 440 base with measurement. Note, when placed on a flat surface without the drain hose, the round part that would sit on the carb is suspended slightly above the surface.
Re: 70 440 4bbl oval baseplate with round lid [Re: 1fastrunner] #112142
11/03/08 12:00 PM
11/03/08 12:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That's a small picture
Re: 70 440 4bbl oval baseplate with round lid [Re: JohnRR] #112143
11/03/08 12:16 PM
11/03/08 12:16 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Here's a modified 69 base to fit under the hood of my son's 67 Dart with a 440. The air cleaner was originally for a 383. I borrowed a 440 base back when I was working on how it would fit in my old 67 Dart. The 440 base was still slightly too tall so the time and effort AND expense to find one made no sense. I have another 383 air cleaner that I will modify the same way when I put my 440 into my 67 Barracuda convertible.
Re: 70 440 4bbl oval baseplate with round lid [Re: JohnRR] #112144
11/03/08 12:20 PM
11/03/08 12:20 PM
1fastrunner Offline
1fastrunner  Offline
How's this?
Page 2 of 3 1 2 3
