Help me choose a killer cam for my 440 #1115682
11/17/11 06:23 PM
11/17/11 06:23 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Here is the rundown of my combo:
-440 STOCK STROKE
-forged pistons
-10,5:1 compression
-440 source stealth heads, port matched bowl blended.
-Performer RPM intake port matched
-440 source adjustable rockers 1,6 ratio
-I have a 750 DP holley carb, although I think it might be too small, or is it OK?
-I plan on using 70.71 HP exhaust manifolds
-full 2,5" exhaust
4,10 gears
4 speed transmission
this is going in a 71 cuda in full street trim.
I was thinking it might be the ticket to use a solid flat tappet cam in here? No, I dont want to spend more on a roller.
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115683
11/17/11 06:41 PM
11/17/11 06:41 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Cam -
Comp Cams Extreme Energy High Lift
EX295HL or XE285HL
4 speed and 4.10
Re: Help me choose a killer cam for my 440 [Re: Biginchmopar] #1115684
11/17/11 06:52 PM
11/17/11 06:52 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
is that a hyd flat tappet?
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115685
11/17/11 07:52 PM
11/17/11 07:52 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
M.P. 528 solid.
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115686
11/17/11 09:06 PM
11/17/11 09:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you'll need more carb. Call Scott Brown. He has a nice solid grind that will work good it's 540-548 lift.
Coming soon!!!!
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115687
11/17/11 09:12 PM
11/17/11 09:12 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
my 440-6 has a 557 /255 with 1.6 ratio rockers
1.39 9.85 - 137 mph
Re: Help me choose a killer cam for my 440 [Re: Lee446] #1115688
11/17/11 09:23 PM
11/17/11 09:23 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I'd run something in the 550 lift range & 250s @50 if your wanting somewhat killer. The .557 MP cam would be on the wilder side for a solid. I ran the last one in my 451 & really liked it, you really need headers if you want a killer type cam.
http://www.jegs.com/i/Mopar+Performance/...0661AC/10002/-1
http://www.jegs.com/i/Mopar+Performance/312/P4120661AC/10002/-1
http://www.jegs.com/i/Comp+Cams/249/21-232-4/10002/-1
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Help me choose a killer cam for my 440 [Re: Biginchmopar] #1115689
11/17/11 09:29 PM
11/17/11 09:29 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Cam -
EX295HL or XE285HL
4 speed and 4.10
XE295HL is a good cam for an engine like yours
Gus
64 Plymouth Savoy
Dana 60
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115690
11/17/11 10:19 PM
11/17/11 10:19 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Less is more. .528 if you want something off the shelf.
Re: Help me choose a killer cam for my 440 [Re: BSB67] #1115691
11/17/11 11:41 PM
11/17/11 11:41 PM
Central NC
gch Offline
gch  Offline
Central NC
I agree.With the manifolds the MP .528 solid would be hard to beat.The .509 hyd would work well also.
Re: Help me choose a killer cam for my 440 [Re: gch] #1115692
11/18/11 12:51 AM
11/18/11 12:51 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
none of the above. i don't like a lot of overlap on cast manifolds.
Re: Help me choose a killer cam for my 440 [Re: lewtot184] #1115693
11/18/11 12:58 AM
11/18/11 12:58 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
iv,e got a new .617 lift solid Lunati, wil sell cheap.
Re: Help me choose a killer cam for my 440 [Re: BSB67] #1115694
11/18/11 01:04 AM
11/18/11 01:04 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
with the .528. Ron
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115695
11/18/11 01:41 AM
11/18/11 01:41 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Get one from indy, it will kill your valve springs.
8.30's @3400 lbs
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115696
11/18/11 03:28 AM
11/18/11 03:28 AM
SoCal
Brian Hafliger Offline
SoCal
-440 STOCK STROKE
-forged pistons
-10,5:1 compression
-full 2,5" exhaust
4,10 gears
242@ .050 on a 110lca. Lift will be about .560 gross and only about .014 lash.
Brian Hafliger
Re: Help me choose a killer cam for my 440 [Re: Lee446] #1115697
11/18/11 05:50 AM
11/18/11 05:50 AM
Europe
BB 70 Challenger Offline
Europe
M.P. 528 solid.
With cast iron stock exhaust manifolds, it is said to work very well.
Iīve heard that so many times. So thatīs the cam I would pick.
Re: Help me choose a killer cam for my 440 [Re: Mr.Yuck] #1115698
11/18/11 06:21 AM
11/18/11 06:21 AM
Hamburg / Germany
Den300 Offline
Den300  Offline
Hamburg / Germany
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115699
11/18/11 08:52 AM
11/18/11 08:52 AM
windsor, onatrio canada
metcoll Offline
metcoll  Offline
use the lunati 30307 grind (240/250 @50 520/547lift) killer mid-range power....
Re: Help me choose a killer cam for my 440 [Re: metcoll] #1115700
11/18/11 01:51 PM
11/18/11 01:51 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I had already bought this cam for this engine:
http://www.summitracing.com/parts/CCA-CL21-225-4/
But I started this thread because I thought it was a bit small and I was leaving power on the table. This is a street car but that will see some strip action. It is a 71 cuda with a 4 speed and 4,10 gears like I said.
How much power do you think Id be making with the above cam, and how much more do you think I could gain by going to a solid like the MP .528" or the Scott Brown?
Re: Help me choose a killer cam for my 440 [Re: domingo] #1115701
11/18/11 02:08 PM
11/18/11 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
remeber the 528 is going to be about 500 once you adjust for lash. I ran both in a 440-6 (528 and the 548) the 548 felt much stronger.
The one you have now seems like a good cam. Just run it
Coming soon!!!!
