Help me choose a killer cam for my 440
#1115682
11/17/11 06:23 PM
11/17/11 06:23 PM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
Here is the rundown of my combo:
-440 STOCK STROKE -forged pistons -10,5:1 compression -440 source stealth heads, port matched bowl blended. -Performer RPM intake port matched -440 source adjustable rockers 1,6 ratio -I have a 750 DP holley carb, although I think it might be too small, or is it OK? -I plan on using 70.71 HP exhaust manifolds -full 2,5" exhaust
4,10 gears 4 speed transmission
this is going in a 71 cuda in full street trim.
I was thinking it might be the ticket to use a solid flat tappet cam in here? No, I dont want to spend more on a roller.
Re: Help me choose a killer cam for my 440
[Re: domingo]
#1115687
11/17/11 09:12 PM
11/17/11 09:12 PM
Posts: 5,618 long island NY
Ari440
long island NY
my 440-6 has a 557 /255 with 1.6 ratio rockers
1.39 9.85 - 137 mph
[Re: domingo]
#1115690
11/17/11 10:19 PM
11/17/11 10:19 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Less is more. .528 if you want something off the shelf.
[Re: BSB67]
#1115694
11/18/11 01:04 AM
11/18/11 01:04 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
with the .528. Ron
[Re: domingo]
#1115695
11/18/11 01:41 AM
11/18/11 01:41 AM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
Get one from indy, it will kill your valve springs.
8.30's @3400 lbs
[Re: domingo]
#1115696
11/18/11 03:28 AM
11/18/11 03:28 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
242@ .050 on a 110lca. Lift will be about .560 gross and only about .014 lash.
Brian Hafliger
[Re: Lee446]
#1115697
11/18/11 05:50 AM
11/18/11 05:50 AM
Posts: 14 Europe
BB 70 Challenger
Europe
M.P. 528 solid.
With cast iron stock exhaust manifolds, it is said to work very well. Iīve heard that so many times. So thatīs the cam I would pick.
[Re: metcoll]
#1115700
11/18/11 01:51 PM
11/18/11 01:51 PM
domingo
EL Master
EL Master
Lima, Peru
I had already bought this cam for this engine: http://www.summitracing.com/parts/CCA-CL21-225-4/But I started this thread because I thought it was a bit small and I was leaving power on the table. This is a street car but that will see some strip action. It is a 71 cuda with a 4 speed and 4,10 gears like I said. How much power do you think Id be making with the above cam, and how much more do you think I could gain by going to a solid like the MP .528" or the Scott Brown?
[Re: domingo]
#1115701
11/18/11 02:08 PM
11/18/11 02:08 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
remeber the 528 is going to be about 500 once you adjust for lash. I ran both in a 440-6 (528 and the 548) the 548 felt much stronger. The one you have now seems like a good cam. Just run it
