My heads only flowed 265 and 180. Nothin killer there. Only 3.58 stroke so I had to turn it 8,000. You have a 4.00" stroke you can turn it considerably less. Your cam is close to what I had. Those eddies should be pretty good. Compression is not everything in my opinion. Flame travel is just as important. Your converter may be a power eating pig. If not I stand by the numbers I posted earlier. Mid 10's.
Leon
Career best 8.02 @ 169 at 3050# and 10" tires small block power.
