Shift timing is waaay off.
What are the critical specs?
some time's you have to fudge the band adjustment a little to get it where it want's to be, is the band lever ratio the same as before? try backing off the band adjustment 1/4 to 1/2 turn and see if that help's,,if you tightened up the clutch running clearance then it engages before the band has released fully.
Light travels faster than the speed of sound,,,this is why some people seem bright untill you hear them speak.
