He's just had it apart and checked alignment of oil holes etc, no blockages etc, but still that particular arm has no oil.
from the beginning you'd (1) want to align the cam bearing & w the rocker shaft assy off (cover #2 pedestal w a no lint rag & preoil it w the drill to see if you have psi then (2) button it up & run it w that valve cover off & see if your getting enough flow from the timed passages in use & you said the rest are good ex for #3. So if the shaft is being fed plenty w the ovalled out shaft hole at the 2nd from the front feed pedestal (for driver side bank) & the mini oiling holes ended up being aligned good w this mod then the only other thing I can think of is some debris from the drilling didn't get cleared out but I'm suspicious of that & yes I think your pics will tell the story & we're missing something right in front of us.
