Aye mate. Check if that rocker arm has any squirt holes that might be blocked/not drilled/angled properly. Check shaft/rocker clearance. might open up the small oiling hole on the shaft at that rocker arm, might take off the valve cover w it idling & see what you observe, it'd b messy but something might b apparent. Holler what it turns out being
