I just loved my BG 280 when I would be up in the staging lanes and fire up my car, I'd hear the BG pump working but no fuel pumping.I'd have to get out fast, keep a -10 AN wrench taped to the cell and crack open the return fitting to let the air out and bleed it.
I know its the fuel pump since after I replaced it with a Product Engineering fuel pump my problems went away.
Same with the POS regulator from BG.
Sent it back because it wouldnt hold 6.5 PSI. It would climb to 13 psi, flooding out my motor.
After $90.00 later, put it back on and same thing happened. So Product Engineering regulator went on a problem solved.
Goodbye BG.
