There have been quite a few problems with the new 6 speed it seems. Why is there no warranty just because you are the second owner? Can it not be transferred? Did you buy it from a dealer? I'd be screaming really load about that one, with the known issues of the 61TE tranny, they should just cover it for you. Not sure if the aftermarket is up to speed on these yet.
The number 5 thrust bearing fails,then takes out planetary gears on some 61te trans. I am pretty sure the original lifetime warranty can not be transfered.
Seen A ton at the shop do the same thing. Darn near welds itself together. Sorry about your luck.
I think you should be loyal & trade your 08 T & C minivan in for a 2011 T & C minivan....
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
