Quote: There have been quite a few problems with the new 6 speed it seems. Why is there no warranty just because you are the second owner? Can it not be transferred? Did you buy it from a dealer? I'd be screaming really load about that one, with the known issues of the 61TE tranny, they should just cover it for you. Not sure if the aftermarket is up to speed on these yet.
The number 5 thrust bearing fails,then takes out planetary gears on some 61te trans. I am pretty sure the original lifetime warranty can not be transfered.
