Is it more likely that the rocker shaft was ovalled from previous use or the pedestal being machined wrong. I had a badly squashed set of shafts that I replaced when I put my motor together.
This guys like everything new Nothing else will do
When you buy these heads you have to remember where they are made.. faking the real thing is no substite for the real thing
