Re: Keisler questions... AGAIN...
[Re: DmanSRT71]
#897417
01/10/11 09:14 AM
01/10/11 09:14 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Here's what I got from Keisler
But for reference, all RS 5-Speed pricing is as follows: RS400 (400 torque, standard ratio) Complete PerfectFit Kit $2295 RS500 (500 torque, standard ratio) Complete PerfectFit Kit $2595 RS400 (600 torque, close ratio) Complete PerfectFit Kit $2995
Bare units start at only $1395. A PRO SHIFTER with internal stops, tunable internal spring bias, and other class leading feaures is STANDARD with EVERY transmission.
When compared to my quote from early 09, the RS would be somewhere $300 ish cheaper than the TKO 600 perfect fit 5 speed conversion (auto to 5 speed in a cuda). So you're still around $5000.
Sorry guys.
Okay, i dont understand this...
RS kit - $2300-3000. (i'd likely use the 400)
TKO (by your accounting) 2600-3300 (which seems low, last Tremec 5-spd quote i got was over $4000)
Where does the $5000 come from...??? (my car is not an automatic)
$2300 is definitely doable. That would be a done-deal.
