Re: Keisler questions... AGAIN...
[Re: DAYCLONA]
#897408
01/08/11 09:57 AM
01/08/11 09:57 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The T45RS is offered in 3 torque levels, IIRC 350, 450, and 600 ftlbs, price for transmission only, and respectively in relation to torque level $1395, $1495, and $1650 IIRC,....depending on what you require in the way of bellhousings, clutch set-ups, pedals, shifters, a hyd TOB upgrade, etc, etc, the price can rise from a minimum of $1400 to a maximum of $3-$3500 for a transmission and conversion kit
I could probably get away with the weakest one, or at most need the middle one. No 440, no strokers, no boost and no NOS in this car... just RPM on the open road.
As for the price, i'll probably be somewhere in the middle... I need the conversion, but only a manual 3spd to a manual 5spd conversion. Should be $2500 or less...???
