Re: Keisler questions... AGAIN...
[Re: DAYCLONA]
#897400
01/07/11 08:44 AM
01/07/11 08:44 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
Like I said call Jeff at Keisler, he'll know the release dates of your application of the T45RS 5spd set-ups, they'll start out at around $1600 transmission only, on up to $3K depending on your application, and parts/options required, as well as torque level desired,...the 68-70 B body application, to my knowledge is done, call to check on the E body applications availability
Mike
Thanks. I'll give him a call next time i get a chance. I need the full kit, but my car is already a stick car (3spd), so i dont need the conversion parts.
This is kind ov a temp fix anyways, as all my super big block plans just fell through permanently. I just need something that will survive a junkyard-nasty 383 or 400 (stock stroke) in a light-ish road car.
