I thought about the high voltage and so what I did is disconnected the bulkhead connector (1st plug in closest to master cylinder) to sort of eliminate the alt and charging system and that didnt change a thing. Rear taillights were still flickering with the idle of the car. I didnt dare rev it up as I didnt want to burn another set of bulbs (they arent cheap anymore)
