Quote: So is that the trash can hat Ryan... looks like a tight turn on it... glad to hear you got it done big numbers.... I've always been a user of 8 egt's
No, that's the Extreme Velocity hat, I did'nt take any today with the home made hat, (imaigine it as being just a full round donut looking hat with a side 3" inlet) but it is in 2 videos I will post up eventually. Yes the "short turn" on the extreme velocity hat is basically the problem, it seperates the motor in 1/2 for most part. It's just a horrible design, adding spacers underneath the hat (ontop of the carb) supposedly helps but I don't have hood clearance for as much spacer as it neeeds I think. Mark said some guy over on turbo forums did some testing with spacers under one & found it took 8" section of pipe under one to get it to have even distribution LOL.
if anyone wants to buy the ExV hat, PM me I'll sell it cheap.
That would make sense... in that hat it looks like most of the air is going down the back wall going to the rear cyl making them lean, so yeah the 8" pipe would help straighten the air out
