Quote: I foolishly had that same combination for a litte (Thermobog on an RPM air gap). Just use an adapter... or better yet use a real carb.
I believe that the Mighty Three have spoken the truth!! Daytona has proved that if you can SEE the mounting for a TQ, it can be mounted WITHOUT an adapter, Doc has proved that the TQ is NOT little as you say, but being a very FLEXIBLE carburetor (fits on any Mopar v-8 regardless of displacement). Scott proved that it doesn't suffer as much from mixture problems as the "other" carb which you call "real". No problems here at ALL with YOU using a REAL carb!! Just food for .
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
