Hello! As I'm reading this, I'm thinking...man, this sounds like the problem I was having...wait, I am the OP! Odd problem. Took a phone call to tech line to figure out. I just un-hooked the door relay and it works fine. The relay is over next to, hooked to the glove box liner. As long as it's un-hooked, works fine. Jeff
Jeff, What was the cause of your gauges not working? The fuel and oil pressure gauges do not work on this car. I did remove the relay and like you said it works fine. I just wasn't sure if there would be any unwanted side effects to doing that. I am glad that you were reading this.....again! Thanks, Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
