Is the air gap in the distributor set properly? I went to fire up my new 440 a few weeks ago0 no spark. It ended up being the air gap was set at .065- 1/16" It should have been .008 max. when I set it correctly it started up immediately.
I sent the distributor to FBO to curve it and they also put in a new pickup coil and did not set the gap properly grrr...
I've thought about that, but haven't checked it yet. I will check it when I get home. Any tips on how to check it? Sitting here thinking about it, I don't see how you could tell what the gap is inside the cap.
