It should not be firing when the valve is opening so if it is pointing at the 6 while the intake is opening you are ok
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
