Quote: Try backing off the timing a little. Also check and make sure you have a good paint free block ground.
I just hooked up the grounds today, and sanded to bare metal on all the ground points. I have an MSD e-curve, so to start, I set the initial timing at 5. The curve I have set is for +26 degrees at 2600 RPM's, so it will be at 31 @ 2600 RPMS, but should still only be 5 for starting.
