A comment on rods... The Eagle is a good rod. I'm running a set on a NA BB around 550 HP. From what I've seen above 700-800 HP they get marginal. You will be way over that in HP so I'd consider either high end steel rods (Oliver?) or a fresh set of aluminum rods.
For the road work are you considering Aero modifications? You'll probably have the HP to approach 200 MPH but it won't stay on the road without come considerable Aero help.
