Quote: If we've learned one thing from our new friend Dave Walden, is that if someone is going to reproduce an item, they should strive to make that item EXACTLY like the original or else it would be just another sub-standard part. Why go 99% of the way, when you can go 100%.
Because
1. Theyr'e a part you hardly ever see.
2. Much cheaper to produce WITHOUT the licensing from Chrysler for the #'s and pentastar.
As for you Mark Mr. gy3, knock off these logical comments, there's those that can't follow that train of thought.
