Wild Bill i may have missed it but did you try adding more timing and fattening up the carb some? i would think it would kill the peak numbers slightly but put bigger numbers at a lower rpm. alcohol motors seem to just keep making power by adding more jet. I see some guys asking if methanol makes that much more power i believe its 10-15% more than gas.
