Quote: 72 440 block bored .030 decked so pistons are .010 in the hole Wiesco Pro Tru pistons 12.05-1 compression K1 rods Facotry forged crank turned .010/.010 and balanced.
Cam Comp cams Magnum series Duration at .050" Lift 262 int./262 exh Actual lift using 1.6 intake and 1.5 exh 578 int and 555 exh. Installed at 108.5*'s
Edelbrock heads Milled to .064 cc chambers Hand ported By Scott Koffel
Those are some good flowing Eddie (RPM?) heads. It is a street/strip type cam (IMO), so with the alky I am thinking 646 hp.
I am curious about the power curve and torque peak with those 2-1/8" headers on a 446 CID. How long are the primaries?
